4' LED "shop" lights for ~ $32 at Costco
   / 4' LED "shop" lights for ~ $32 at Costco #112
I snagged 4x of them on sale today.
Over the last couple years I have bought a dozen. This is the best price. In the past it has varied from $29 down to $24 then $19 then back up to $29. Suggest you load up now if you have the need in the coming year.
   / 4' LED "shop" lights for ~ $32 at Costco #113
Menards has 4 footers for 16 bucks and change...
I bought four of them last night...
SR
   / 4' LED "shop" lights for ~ $32 at Costco #114
Are the Costco LED fixtures plug-in only?
   / 4' LED "shop" lights for ~ $32 at Costco #116
Rural King has the 4-foot single row 3000 lumen for $16.99 and 2-row 4500 lumen for $19.99.
   / 4' LED "shop" lights for ~ $32 at Costco #117
One of our kitchen fluorescent fixtures went out. It is in a box with two 2x4ft fixtures in it. All the costco LED shoplights I installed a couple years back are working fine so I went to get some more, no luck, not in stock. But as it happens Amazon now has LED shoplights at a similar price, $28. They are linkable and can also be flushmounted which is what I need in the kitchen light box. I was going to adapt the hanging costco LED but this is even easier.
LED Shop light for garages, 4FT 48LM, 42W 5K Daylight White, LED ceiling light, LED Wrapround light, With Pull Chain (ON/OFF), Linear Worklight Fixture with Plug, cETLus Listed 1PACK 5K - - Amazon.com
   / 4' LED "shop" lights for ~ $32 at Costco #118
I looked at the Amazon LED kits the last time this was mentioned. Aside from color, there is another aspect to watch: some kits come with the short power cords to string the fixtures in series, for other brands that cable set or even the wall cable with inline switch, is an option you buy separately. So consider this when comparing price.
   / 4' LED "shop" lights for ~ $32 at Costco #119
Rural King has the ... 2-row 4500 lumen for $19.99.
I think that's the same as what I saw at Tractor Supply for the same price. Possibly TSC's were shorter - I didn't notice the length.
I wonder if they were TSC's Monthly Special which are usually interesting and a good value.
   / 4' LED "shop" lights for ~ $32 at Costco #120
When comparing or shopping for these, be sure to note the lumens. There is a wide margin of light output all being sold as "shop lights", so do your homework. Some produce lower light than T8 or T12 lamps, while others produce much more light.
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2018 Dodge Ram 3500 (A57148)
2018 Dodge Ram...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
2021 Ford F-450 4x4 Crew Cab Liftmoore 3612 1.5 Ton Crane Service Truck (A55973)
2021 Ford F-450...
2019 GALYEAN...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58216)
30 INCH TOOTHLESS...
