4' LED "shop" lights for ~ $32 at Costco
   / 4' LED "shop" lights for ~ $32 at Costco #101
That's a steal! Just the housing is worth most of that as scrap steel!
   / 4' LED "shop" lights for ~ $32 at Costco #103
   / 4' LED "shop" lights for ~ $32 at Costco #106
   / 4' LED "shop" lights for ~ $32 at Costco #108
I have 8’ fixtures with 2 x 8’ T12 bulbs, that hang on chains, 16’ above my shop floor. The 8’ tubes are a PIA to change out.
I’m replacing the entire fixtures with these.
EnviroLite 8 ft. 4-Light White Industrial LED White Strip Light with T8 LED 5K Tubes-ST74T185 - The Home Depot
Each fixture has 4 x 4’ T8 size LED tubes.
Hey, thanks for that link. That's exactly what I need to replace the 8' fixtures in my barn. And you're right - those 8' bulbs are a PITA to change.
   / 4' LED "shop" lights for ~ $32 at Costco #109
Good luck, you’ll like them.
   / 4' LED "shop" lights for ~ $32 at Costco #110
Just got 3 of the Feit Electric 4' dual tube led fixtures that Costco has on sale for $19.99 each; took one out and plugged it in, gives off great light, compatible with the florescent but brighter. They have 5 foot cords and can be ganged together as the other end has a receptacle.
I'm going to replace one bank in the shop with these, so it will be easy to compare with the other side; I expect these to be superior.
2006 John Deere 120C Hydraulic Excavator (A56857)
2006 John Deere...
(4) LT265/75R16 USED TIRES (A58374)
(4) LT265/75R16...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
(2) HD ALUMINUM RIMS (A58374)
(2) HD ALUMINUM...
(3) FUEL TANKS (A52708)
(3) FUEL TANKS...
2014 Kaufman 12,000 Lb. Trailer, VIN: 5SHFD2225EB000634, Tandem Axle, Wood Deck, Tilt Deck, Asset# (A59076)
2014 Kaufman...
