Gopher blaster/rodent blaster
/ Gopher blaster/rodent blaster #1
dennisleary
Brooks, Ca
kubota 4760
Anybody have an opinion on these?
They cost $$ but seem fun to use.
I've seen mixed reviews on the Internet but it's hard to figure out if the positive reviews are just made by sales people in disguise...
Thanks
/ Gopher blaster/rodent blaster #2
Seems to me that I could build one for 1/10 or less what they are asking. I'd need a lot of gophers/groundhogs/whatever to justify that.
/ Gopher blaster/rodent blaster #3
I think it would be more fun to use on humans.
/ Gopher blaster/rodent blaster #4
It doesn't really look effective, but boy does it look like fun! :)
/ Gopher blaster/rodent blaster #6
Thanks
Is there a Link to this?
/ Gopher blaster/rodent blaster #9
I had no idea I needed one of these, until I saw the video.
:laughing:
Now I want one.
/ Gopher blaster/rodent blaster #10
Well not nearly the fun, but if you just buy a HF weed burner with auto ignitor for $29.99 it will do away with the underground pest just as easily. Maybe not even need to ignite, just fill hole with propane and suffocate the little ##$#$. Propane being heavier than air will settle into the lower regions of the burrow and displace the air. No need to ignite unless you just want to watch it burn.
It is insane to charge $1600 for that Rodenator gizmo.
/ Gopher blaster/rodent blaster #11
I figured I'd start with exactly what you mention. Around here, we only get moles, and where I'm now at, the ground is soooo compacted, I'm thinking of importing a few!
/ Gopher blaster/rodent blaster #12
For $1600 I'll continue to use my spring type gopher traps. That's simply crazy expensive.........
/ Gopher blaster/rodent blaster #13
It only makes sense if you're removing gophers in a large acreage (or for customers) and don't have a fire season. The people who eradicate gophers as a business here use cinch traps.
/ Gopher blaster/rodent blaster #14
To answer the question of how do you know they work, I rake or drag the area I just worked on,leaving no mounds, then watch for new activity.
I too, sometimes use the burning sulfur/propane torch method, but I find that occasionally, you get a smart gopher that plugs the tunnel when they hear the activity on the surface. Again raking the mounds will show new activity in the area
Traps are hit and miss for me, although I do have a lucky blue cinch trap that has done well for me.
/ Gopher blaster/rodent blaster #15
Cinch traps only work in active burrows. When I an trapping I have to go out at least once a day to check for new burrows and place traps. I'll do that until I have eradicated all the gophers in the area I'm trapping (a large lawn and a garden) then I can ignore it for a few weeks until a new gopher arrives. It's taken me a while to get effective with the traps. With some gophers it takes a number of resets of the trap to catch them. But I can pretty much guarantee that I'll get them eventually.
On some of the traps I've done some tuning to make them trip easier- sanding down the end of the trigger wire and the sliding wire where it slides in the base. It helps some.
/ Gopher blaster/rodent blaster #16
That is way overpriced for the hardware you get!
Rogator RG1100 (A63688)
Rogator RG1100...
LOOK! (A63111)
LOOK! (A63111)
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2019 MACK PINNACLE (A63569)
2019 MACK PINNACLE...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
