dragoneggs
Super Star Member
- Joined
- Jun 9, 2013
- Messages
- 14,548
- Location
- Seabeck, Washington
- Tractor
- Kubota BX-25D, Kubota Z122RKW-42
If it were my choice, I’d pick black. White maybe will get dingy looking. Red too flashy.
If it were my choice, I壇 pick black. White maybe will get dingy looking. Red too flashy.
I have had stuff sandblasted and painted for years now. In other words, it's a yearly ritual. My trailer hitch on my 08 GMC started to rust quite quickly. Twice, I removed it, had it sandblasted, painted it with tremclad and baked the paint. It just rusted again. Not sure what to make of this.
So although I have no issue with blasting and painting implements, I have serious reservations about spending any money on something that is already rusted and will be exposed to further road salt.
Under painting something has probably rarely been my problem. People always spoke of recycled steel already having the rust built in. Knowing the steel making process, I consider this unlikely but this stupid (oem)trailer hitch makes me wonder.
After the blasting apply some phosphoric acid. That'll neutralize all rust that is left but you can't see.
Rams, I did get the pics... very nice trailer and worth the effort of maintenance. Thanks for sending. I figured you would go with the dirty white since it is original. I get it. Doesn't matter on the color... just git er done. I commend you for doing the maintenance and upkeep on a very nice trailer. :drink:The trailer was originally white, I was just about convinced to go with black and then I noticed some of the Conex boxes (shipping containers) that were painted an off white or almond color. KInd of a dirty white. We talked about it and I decided to go with it. It's available in rattle cans for touch ups (we all know it's gonna get scratched up eventually) and will still look off white whether its clean or dirty. I can live with that.To each their own I guess. :drink:
Edited: BTW, did you get the pictures I emailed to you?
Rams
Black is one of the hardest colours to keep clean. The off white will e much easier.
Don't use any type of acid products if you are planning to use epoxy primer unless you know how to properly neutralize the acid. If your project has seams or areas that the acid may be difficult to remove, it wouldn't be wise to use it at all. I wouldn't recommend acid for anyone that does not have a lot of experience with prep and paint work. The consequences can be disastrous.
Here's what I use and never had a problem with paint failing. Rust Inhibiting Coating SKYCO OSPHO 1 Gallon - Whitehead Industrial Hardware
Ospho works. I ran a test in Florida. I had several light poles with a steel plate holding the lamp to the post. I did 3 of the steel plate with Ospho, followed by cold galvanizing spray paint, followed by an inexpensive top coat from a spray can. Another 3 I did the same way but left the Ospho step out. Results after 3 years: The ones with the Ospho showed no signs of corrosion. The ones without was showing the beginnings of corrosion. 7 years later (10 total) the ones with Ospho still did not show signs of corrosion. The others needed to be redone. I sold the house before I ever found out how long the Ospho protected them. I also found that after sandblasting, if you'll allow a very light coat of rust to form before applying Ospho, the Ospho works better. It appears to work by converting the iron oxide to iron phosphate which clings very tightly to iron whereas iron oxide (rust) just flakes off.
