top link question
/ top link question #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Anyone know where I can buy a top link with a class II on one end and a class I on the other? Class II is too wide to fit on a 3 pt hay fork. I'll cut the connection apart and re weld on the implement if necessary but a hybrid top link would be much easier.
/ top link question #2
So you want a cat 2 tractor end and a cat 1 rod end, or just a narrow (1 3/4") cat 2 rod end?
I can build whatever you need. What tractor is this for?
/ top link question
More narrow rod end is fine. JD 6403
/ top link question #4
I made one up and have been using it for years. The threads are the same so I just bought a CAT II end. I like it because it's not so bulky and heavy.
Probably got it at TSC
/ top link question #6
when i got my new 3930 ford newholland it came with it just like you want.
/ top link question #8
Hello joeu235, when I had that problem I just ground down one end of a cat II top link to fit (both sides so it stayed centred ).
/ top link question #9
I did the same thing once so it fit into the narrow hitch on the tractor. It was a Cat II in pin size but too narrow for the ball to fit so a couple minutes with a grinder solved the problem.
/ top link question #10
They make them. Alot of cat 1/2 oem tractors come from the factory with just such a toplink.
My own Kubota MX toplink is like that.
/ top link question
Thanks for the replies. I probably would have just ground down one end but since my dad is the nominal owner of this tractor, I went ahead and cut and welded the connection on the implement.
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2021 CAM P3612TT 6x12 Utility Trailer (A64047)
2021 CAM P3612TT...
211298 (A62131)
211298 (A62131)
2021 John Deere Z930M Zero Turn (A63116)
2021 John Deere...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
