top link question
/ top link question #1
joeu235
Little River, TX
John Deere 4020 / 6403 / 317 Ford 5600
Anyone know where I can buy a top link with a class II on one end and a class I on the other? Class II is too wide to fit on a 3 pt hay fork. I'll cut the connection apart and re weld on the implement if necessary but a hybrid top link would be much easier.
/ top link question #2
So you want a cat 2 tractor end and a cat 1 rod end, or just a narrow (1 3/4") cat 2 rod end?
I can build whatever you need. What tractor is this for?
/ top link question
More narrow rod end is fine. JD 6403
/ top link question #4
I made one up and have been using it for years. The threads are the same so I just bought a CAT II end. I like it because it's not so bulky and heavy.
Probably got it at TSC
/ top link question #6
when i got my new 3930 ford newholland it came with it just like you want.
/ top link question #8
Hello joeu235, when I had that problem I just ground down one end of a cat II top link to fit (both sides so it stayed centred ).
/ top link question #9
I did the same thing once so it fit into the narrow hitch on the tractor. It was a Cat II in pin size but too narrow for the ball to fit so a couple minutes with a grinder solved the problem.
/ top link question #10
They make them. Alot of cat 1/2 oem tractors come from the factory with just such a toplink.
My own Kubota MX toplink is like that.
/ top link question
Thanks for the replies. I probably would have just ground down one end but since my dad is the nominal owner of this tractor, I went ahead and cut and welded the connection on the implement.
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2008 KOMATSU PC200LC-8 HYDRAULIC EXCAVATOR (A64047)
2008 KOMATSU...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2018 HINO 258A REEFER TRUCK (A63569)
2018 HINO 258A...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
Duo Lift Sprayer Trailer (A64047)
Duo Lift Sprayer...
