   / Share Pics of People Hauling or Towing Something Wrong #6,681
Here is a ironic pic for you all, see if you can spot why on the load.
   / Share Pics of People Hauling or Towing Something Wrong #6,683
   / Share Pics of People Hauling or Towing Something Wrong #6,684
Maybe not tied down but you can't tell for sure in the picture. The trailer doesn't appear to be sitting level but that's not a big deal as light as it's loaded.
   / Share Pics of People Hauling or Towing Something Wrong #6,685
   / Share Pics of People Hauling or Towing Something Wrong #6,686
It wasn’t tied down, I wasn’t going very far and didn’t bother to tie it down past setting the ebrake on the mower.
The truck has a pintle hitch stuffed in the receiver which I can’t get out, I shot PB blaster in it for a week, hit it with a sledge, even wrapped a chain around a tree and lightly tugged on it, didn’t budge, I can’t see that it’s welded in but idk. IMG_9429.JPG
It’s set on the highest bolt holes, I need to lower it to level the trailer.
That’s a 54in, 24hp husqvarna mower with 272h I bought for $800, used it for 2 seasons, replaced all the idler pulleys on the deck, replaced the voltage regulator and bought two $35 set of blades, I had around $1000 in it and sold it yesterday for $1100.
   / Share Pics of People Hauling or Towing Something Wrong #6,687
I don't trust my lawnmower brakes very much. I usually hook a loose chain on the front.
   / Share Pics of People Hauling or Towing Something Wrong #6,688
If the mower rolls out the back, simply tell the buyer that the deliver fee is 1,099 and that the tractor is only $1, so then they cant complain about any damage.
   / Share Pics of People Hauling or Towing Something Wrong #6,689
It’s HST also, if it started rolling it had 12ft of trailer to slowly roll-on before I could get stopped, I think my Max speed was around 45 on that trip.
   / Share Pics of People Hauling or Towing Something Wrong #6,690
It wasn稚 tied down, I wasn稚 going very far and didn稚 bother to tie it down past setting the ebrake on the mower.
The truck has a pintle hitch stuffed in the receiver which I can稚 get out, I shot PB blaster in it for a week, hit it with a sledge, even wrapped a chain around a tree and lightly tugged on it, didn稚 budge, I can稚 see that it痴 welded in but idk. View attachment 532392
It痴 set on the highest bolt holes, I need to lower it to level the trailer.
That痴 a 54in, 24hp husqvarna mower with 272h I bought for $800, used it for 2 seasons, replaced all the idler pulleys on the deck, replaced the voltage regulator and bought two $35 set of blades, I had around $1000 in it and sold it yesterday for $1100.
When those hitches rust into the receiver it's like they welded themselves together. You could try a beefy slide hammer, but I'm thinking that if you already tried hooking it to a tree and hit it with a sledge that's probably not going to do any better. At least it could develop some shock/spike load that you maybe didn't do with the tree and in the right direction compared to the sledge. Just another idea.
Rob
COMPLETE 18' X 30' X 10' GARAGE BASEPLATE UNIT (A58374)
COMPLETE 18' X 30'...
2017 Hino 155 Truck, VIN # JHHUDM1H6HK002446 (A56858)
2017 Hino 155...
2008 DRAGON PNEUMATIC TRAILER (A58214)
2008 DRAGON...
INVERSION DEVICE (A58374)
INVERSION DEVICE...
2004 Ford F-150 (A56858)
2004 Ford F-150...
2004 PROCO 130BBL VACUUM (A58214)
2004 PROCO 130BBL...
