   / Share Pics of People Hauling or Towing Something Wrong #6,703
That's it! I haven't been using it for very long (had not used Fluid Film- when I went to first purchase Fluid Film I saw Slick Stuff and grabbed it instead). I CAN say that is smells great:D (actually, it's worked pretty well on my car door hinges; used it on PTO shafts but it's kind of hard yet to say how that is going)
   / Share Pics of People Hauling or Towing Something Wrong #6,704
I tried a sledge hammer first, side to side, front and back the best I could threw the week I was soaking it with PB blaster multiple times a day, no luck.
Although I just let the sledge do the work, I didn稚 try to destroy the thing.
After that failed I tugged on a tree a bit lol again not trying to break something, the thing didn稚 budge a bit and I said the heck with it and put the pin back in.
I guess instead of changing ball mounts I値l just have to get used to changing balls on this pintle set up.
Try hooking up a come along to it and to another vehicle with a hitch. Apply as much pressure as possible, and them smack it with a sledge while standing out of the way of flying objects. Keep pressure on it, spray whatever to loosen and keep smacking it. And/or use an air impact chisel like the one Diesel Bound showed a picture of. I had to do this when I had a 1 1/4" solid square hitch bar on the mini van hitch. (This is also why I never leave a hitch bar in the receiver.) Jon
   / Share Pics of People Hauling or Towing Something Wrong #6,705
PB is good for everyday uses. But when it don’t work try Kano. Let it soak just like you have been doing with the PB. Penetrating-Lubricating Oils
If the Kano don’t work it’s time for the air chisel and liquid wrench (cutting torch).
   / Share Pics of People Hauling or Towing Something Wrong #6,706
I had a stuck hitch and sprayed it from the backside. Took a while but oil and constant pulling pressure on it and it came loose.
   / Share Pics of People Hauling or Towing Something Wrong #6,707
I had a locking pin in a 3-way ball mount, only ever used it one way up. Locking pin froze in, even with lock part off. Since I was in the process of selling the truck, I didn't bother trying to drill it out and just bought another ball mount...but I don't leave it in the hitch anymore on the (slightly) newer truck.
   / Share Pics of People Hauling or Towing Something Wrong #6,708
If you plan on leaving a hitch in the receiver (so some yahoo doesn't rear-end you) then dip the end in fluid film or motor oil before inserting into the receiver. It will repel water and resist corrosion.
   / Share Pics of People Hauling or Towing Something Wrong #6,709
Did you try heating it up with a torch while you were putting pressure on it. Heat does wonders
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
14C SCRAPER (A58214)
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
Mini Skid-Steer 4-in-1 Bucket (New/Unused) (A59225)
Mini Skid-Steer...
HELI 25 STRAIGHT MAST FORKLIFT (A52709)
HELI 25 STRAIGHT...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
