   / Share Pics of People Hauling or Towing Something Wrong #6,703
That's it! I haven't been using it for very long (had not used Fluid Film- when I went to first purchase Fluid Film I saw Slick Stuff and grabbed it instead). I CAN say that is smells great:D (actually, it's worked pretty well on my car door hinges; used it on PTO shafts but it's kind of hard yet to say how that is going)
   / Share Pics of People Hauling or Towing Something Wrong #6,704
I tried a sledge hammer first, side to side, front and back the best I could threw the week I was soaking it with PB blaster multiple times a day, no luck.
Although I just let the sledge do the work, I didn稚 try to destroy the thing.
After that failed I tugged on a tree a bit lol again not trying to break something, the thing didn稚 budge a bit and I said the heck with it and put the pin back in.
I guess instead of changing ball mounts I値l just have to get used to changing balls on this pintle set up.
Try hooking up a come along to it and to another vehicle with a hitch. Apply as much pressure as possible, and them smack it with a sledge while standing out of the way of flying objects. Keep pressure on it, spray whatever to loosen and keep smacking it. And/or use an air impact chisel like the one Diesel Bound showed a picture of. I had to do this when I had a 1 1/4" solid square hitch bar on the mini van hitch. (This is also why I never leave a hitch bar in the receiver.) Jon
   / Share Pics of People Hauling or Towing Something Wrong #6,705
PB is good for everyday uses. But when it don’t work try Kano. Let it soak just like you have been doing with the PB. Penetrating-Lubricating Oils
If the Kano don’t work it’s time for the air chisel and liquid wrench (cutting torch).
   / Share Pics of People Hauling or Towing Something Wrong #6,706
I had a stuck hitch and sprayed it from the backside. Took a while but oil and constant pulling pressure on it and it came loose.
   / Share Pics of People Hauling or Towing Something Wrong #6,707
I had a locking pin in a 3-way ball mount, only ever used it one way up. Locking pin froze in, even with lock part off. Since I was in the process of selling the truck, I didn't bother trying to drill it out and just bought another ball mount...but I don't leave it in the hitch anymore on the (slightly) newer truck.
   / Share Pics of People Hauling or Towing Something Wrong #6,708
If you plan on leaving a hitch in the receiver (so some yahoo doesn't rear-end you) then dip the end in fluid film or motor oil before inserting into the receiver. It will repel water and resist corrosion.
   / Share Pics of People Hauling or Towing Something Wrong #6,709
Did you try heating it up with a torch while you were putting pressure on it. Heat does wonders
2021 Ford F-350XL (A57148)
2021 Ford F-350XL...
ST205/75R15 Trailer Tires (A55787)
ST205/75R15...
(2) CIRCULAR SAWS (A58374)
(2) CIRCULAR SAWS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Volvo L306 (A57148)
Volvo L306 (A57148)
2014 Freightliner MT55 Step Van (A56858)
2014 Freightliner...
