   / Share Pics of People Hauling or Towing Something Wrong #6,681
Here is a ironic pic for you all, see if you can spot why on the load.
   / Share Pics of People Hauling or Towing Something Wrong #6,683
   / Share Pics of People Hauling or Towing Something Wrong #6,684
Maybe not tied down but you can't tell for sure in the picture. The trailer doesn't appear to be sitting level but that's not a big deal as light as it's loaded.
   / Share Pics of People Hauling or Towing Something Wrong #6,685
   / Share Pics of People Hauling or Towing Something Wrong #6,686
It wasn’t tied down, I wasn’t going very far and didn’t bother to tie it down past setting the ebrake on the mower.
The truck has a pintle hitch stuffed in the receiver which I can’t get out, I shot PB blaster in it for a week, hit it with a sledge, even wrapped a chain around a tree and lightly tugged on it, didn’t budge, I can’t see that it’s welded in but idk. IMG_9429.JPG
It’s set on the highest bolt holes, I need to lower it to level the trailer.
That’s a 54in, 24hp husqvarna mower with 272h I bought for $800, used it for 2 seasons, replaced all the idler pulleys on the deck, replaced the voltage regulator and bought two $35 set of blades, I had around $1000 in it and sold it yesterday for $1100.
   / Share Pics of People Hauling or Towing Something Wrong #6,687
I don't trust my lawnmower brakes very much. I usually hook a loose chain on the front.
   / Share Pics of People Hauling or Towing Something Wrong #6,688
If the mower rolls out the back, simply tell the buyer that the deliver fee is 1,099 and that the tractor is only $1, so then they cant complain about any damage.
   / Share Pics of People Hauling or Towing Something Wrong #6,689
It’s HST also, if it started rolling it had 12ft of trailer to slowly roll-on before I could get stopped, I think my Max speed was around 45 on that trip.
   / Share Pics of People Hauling or Towing Something Wrong #6,690
It wasn稚 tied down, I wasn稚 going very far and didn稚 bother to tie it down past setting the ebrake on the mower.
The truck has a pintle hitch stuffed in the receiver which I can稚 get out, I shot PB blaster in it for a week, hit it with a sledge, even wrapped a chain around a tree and lightly tugged on it, didn稚 budge, I can稚 see that it痴 welded in but idk. View attachment 532392
It痴 set on the highest bolt holes, I need to lower it to level the trailer.
That痴 a 54in, 24hp husqvarna mower with 272h I bought for $800, used it for 2 seasons, replaced all the idler pulleys on the deck, replaced the voltage regulator and bought two $35 set of blades, I had around $1000 in it and sold it yesterday for $1100.
When those hitches rust into the receiver it's like they welded themselves together. You could try a beefy slide hammer, but I'm thinking that if you already tried hooking it to a tree and hit it with a sledge that's probably not going to do any better. At least it could develop some shock/spike load that you maybe didn't do with the tree and in the right direction compared to the sledge. Just another idea.
Rob
John Deere 12in Channel Tooth Bucket Excavator Attachment (A55973)
John Deere 12in...
2000 Nabors 46ft. 40 Ton T/A Flatbed Equipment Trailer (A55973)
2000 Nabors 46ft...
20FT X 30FT STEEL CARPORT (A58216)
20FT X 30FT STEEL...
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2022 FORD F-250 (A58214)
2022 FORD F-250...
2011 MACK PINNACLE (A58214)
2011 MACK PINNACLE...
