Plow size
/ Plow size #1
Jonathan70
CT
2538 CAB HST
How big a plow are you guys putting on the front of a tractor for snow removal ? Have a 2538 Mahindra ,,, looking @ a 7?6 used plow to adapt to my new Titan QA / 3 pt hitch set up for my FEL...
/ Plow size #2
The highest percentage of people would use an 84" wide blade for a Mahindra 2538.
Travis
/ Plow size #3
I have a 10' box pusher....5083E JD. I had as big as a 96" plow on a sub-frame mount for an L3400. I had some issues pushing that uphill with one set of chains and loaded rears.
/ Plow size #4
I run a similar size tractor and adapted a 7' 6" truck plow to a QA plate and ran hyd. lines from one rear remote to the front for power angle. Also run a 7' blower on the back.
/ Plow size #5
Plow angle at 45 degrees should clear rear tires least 6" so they say...start at 7'6".
/ Plow size
Small world grew up in Torrington... there are more plow blades on Craig痴 list everyday ..
/ Plow size #8
We go to Torrington when we go into "town".
/ Plow size #9
I think you will be fine.
Just take smaller bites if necessary.
The issue is going to be pushing the tractor sideways. Running at full angle, and the plow a good ways ahead of the front axle....has alot of lateral leverage. But again, you can just take smaller bites.
/ Plow size #10
I use a 7'6" Diamond unit with my Titan 3PT QA on my LS XR4140 unit. Its more than capable. If I had the option again, use the same size plow.
IMG_9802.jpgIMG_9803.jpgIMG_9804.jpgIMG_9805.jpgIMG_9806.jpgIMG_9807.jpgIMG_9808.jpgIMG_9779.jpg
/ Plow size
Picked up a 3 trip spring Meyers plow : 7’-6” on Saturday .... guy kept lowering his price as we talked ... think the angling pistons are seized up... the hydraulic hose couplings are rusted together... overall the plow is in decent shape... just looking for a couple local welders to call me Back now to see about fabrication of a couple brackets to weld onto the plow frame that I can then attach to the 3 point mounts. Already scooped out new pistons & hoses... just trying to decide on the 3 rd function valve assembly I’ll need if I want to power Angle the plow or just pivot the blade and pin it where I want it...
/ Plow size #12
Picked up a 3 trip spring Meyers plow : 7?6 on Saturday .... guy kept lowering his price as we talked ... think the angling pistons are seized up... the hydraulic hose couplings are rusted together... overall the plow is in decent shape... just looking for a couple local welders to call me Back now to see about fabrication of a couple brackets to weld onto the plow frame that I can then attach to the 3 point mounts. Already scooped out new pistons & hoses... just trying to decide on the 3 rd function valve assembly I値l need if I want to power Angle the plow or just pivot the blade and pin it where I want it...
Are you looking to use this on the front or rear of your tractor? Look at my previous post, I didn't have to weld anything, I just bought the correct quick attach plate and everything connected up. I ran lines from my rear hydraulic connections to angle the plow. We got a couple feet of snow and ice this weekend and everything worked great.
The plate I used: Three Point Adapters - Quick Tach Attachments - Tractor Attachments
/ Plow size #13
Go with the hydraulic angle. I did the manual pivot for 1 season, and then ran hoses from the back of the tractor to the front to control the plow angle. Will also come in handy if you get a grapple.
Was able to repair my plow this week, got the broken pin out and replaced both with new. Of course, its too cold to snow now!
/ Plow size
Thought about running hydraulics from the rear as well, however my rear lines are set up to feed my backhoe..yes I have quick connect fittings .... but
I don’t have a rear remote hydraulic control in the cab.... so I would need to have valve fed from the rear lines with a control of sorts to the cab & then run lines underneath up to the loader ...
/ Plow size
I have the same QA plate. Issues are that the plow mount pin is 5/8 & the 3 point mount pin is 1-1/8 .... see the problem ?
/ Plow size #16
What about using a sleeve? I have cat 2 on my tractors lower links and I use cat 1 attachments all the time
I have an old western plow (which now needs a new cutting edge after a few seasons of use). It’s 7’6””. I used to ha e it sit far out like the diamond blade posted on here but it seemed to add stress to the plow side bracket. I had it cut down and brought in a little. Works fantastic. Mine is not hydraulic yet as I keep wanted to add the cylinders. I already have third function to control it but just can’t seem to find the time
Coupled with the from blade, I use a Servis 8’ rear blade offsetso I am clearing about 9’ whole traveling down the road. I just wish my front blade was hydraulic.
/ Plow size #17
Here's how I mounted my plow. Welded on two boxes to the quick attach plate where the A frame of the plow attach via pins. Welded on a D ring to attach the plow's lift chain to. When I curl the plate backwards, it picks the plow up so I don't actually have to lift the loader arms unless I need to get the plow more than 18" high.
/ Plow size #18
That’s a pretty good design. I had a friend weld mine up. I’ll GT a photo and post it. Yours looks good
/ Plow size #19
I was too cheap to buy a ssqa plate. So I take my forks off and welded my hookups to the fork carrier
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
1829 (A61574)
1829 (A61574)
Beverage Truck Body (A61573)
Beverage Truck...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
John Deere 4300 32HP Loader Utility Tractor (A61572)
John Deere 4300...
