1993 L3450 Hazard Lights problems
/ 1993 L3450 Hazard Lights problems #1
robhannan
Linden, TN
Kubota L3450
I am a new member today. I recently bought a 1993 Kubota L3450-DT in Alabama with 600+ hours and a front loader and bucket. Runs good and while it has wear and tear, it was a good purchase I think. Here are my problems. I fixed the fuel gauge (connector to sensor top of tank was disconnected), no tail light (bought a new tail and a new rear wiring harness and now got a tail light), Here's the problem: hazard lights not working (bought a new rear wiring harness, and a new combination switch for dash, and checked 10A fuse for hazard lights, but still no indication of power flow to the connectors on the wiring harness to the hazard lights). Also, need a SMV bracket to mount the SMV sign. Ordered a new fuel stop solenoid because key off did not stop engine. All advice appreciated. I am new to diesel and tractors but smart and soak up got advice. The electrical problem with the hazard lights having no power is my big problem. Thanks to any who can offer some advice.
/ 1993 L3450 Hazard Lights problems #2
Welcome to TBN - there's a flasher 34220-33700 that operates the hazard lights (#130 on the parts drawing). The pic is from Messics.
  • L3450 switches.pdf
Thank you rbargeron. Appreciate it. Think I will order the original unit from Messick's since I think I also want to replace the air cleaner sensor.
/ 1993 L3450 Hazard Lights problems #4
My L4150 1990 vintage has a bad connection at the fuse socket. Try to jiggle the fuse for the flashers. You might freshen the connection by slighlty bending the blades on the fuse.
Thank you for the tip. I will try that. I noticed the fuse sockets were crusty.
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
2020 ASV RT65 (A60462)
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2014 Timpte Hopper Bottom (A61307)
2014 Timpte Hopper...
2024 MAC TNAR39FR540 40FT T/A  FRAMELESS END DUMP TRAILER (A59906)
2024 MAC...
