/ Harbor Freight Tools that don't suck #8,101
I have several of the plastic drawer units, both large and small drawer types. Too many times I have pulled out dozens of drawers in succession looking for something I know was in there a couple of years ago but I've forgotten which drawer.
I prefer the stuffed-olive slender glass jars. Even if there are dis-similar objects in one jar I can find that odd item - for example a sewing thimble - faster than popping open dozens of drawers. The only drawer set I prefer over my jars is the set containing Metric nuts, bolts, washers all in one place.
I should have noted in my filing cabinet I also have flat sectioned boxes containing multiples of the same washer size so I can find them instantly. The jars are more for random stuff that might not be used for a while like that thimble, a cabinet latch, etc.
"Whenever you look for something you don't find it until you finally get to the last place you search". BTDT, a lot. :)
/ Harbor Freight Tools that don't suck #8,102
A problem with open bins is accumulation of dust and dirt in with the parts, especially sawdust if you're going to do any woodworking. I'm partial to the pullout clear plastic drawers for small parts. Hang two or three of these units side by side on the wall, or stand up at the back of a work bench: 4 Bin Organizer with Full Length Drawer
No wood working, but we are a horse farm. Even though my shop is in a separate building from the horses.... oh the dust we accumulate..... I will look at this closed drawer system.
/ Harbor Freight Tools that don't suck #8,103
I bought 2 sets of these to mount to the wall. I have them 4 across and 8 or so down. 1st row is short-ish bolts, 2nd is long-ish, 3rd is nuts and 4th is washers. To the left of each row I have a sample bolt stapled to the wall with the size of the bolt. I go to TSC and buy a bunch of common sizes by the pound from 1/4" up to 5/8" I think. Painless to get what I need when working on a project but I am due to refill some, that's where the written sizes help. Easy to pop off the bins I need to bring closer to the project. Of course I have spilled them but I still prefer them over other options. These are in my walkout basement so not much for a dust issue. Wood gets worked on outside. I have yet to break one but I have extras if needed.
2 Piece Poly Bins and Rails
/ Harbor Freight Tools that don't suck #8,104
There are pros and cons to all three of these approaches. No need to limit yourself to just one.
With the plastic drawer system, you can pull the drawer all the way out and carry it to your workbench or work space. Same with California's jar system. Harder to do with a bin that is attached to others. Getting to the right part at the bottom of the drawer is pretty easy, without having to dump the contents out, as I've sometimes had to do with jars.
California's right about sometimes having to pull out a dozen drawers to find that pesky part that you know you have there somewhere. But the transparent drawer fronts get me close, and I've used the system for so many years, I can usually guess right the first or second time. Besides, I've always liked to play Concentration. :laughing:
/ Harbor Freight Tools that don't suck #8,105
All you have to do to find something quickly is to look in the last place first. :D
Bruce
/ Harbor Freight Tools that don't suck #8,106
Is it the same as Kubota? Ariens And Kubota Are Chevrolet Engine Orange.
Now if I could match Honda snow thrower red.
Kioti is exactly Chevy Engine Orange. I think Kubota is less bright and certainly different from Kioti.
/ Harbor Freight Tools that don't suck #8,107
I have something similar for bolt storage , not sure were I got it though ???? Bins mount to a rail , which is mounted to the wall in shop .
Started with 1/4" by 1/2" on the left and size in length goes up as you go across to the right . Last 3 bins have lock washers , flat washers and the nuts for that size . Below that is 5/16" , then 3/8" , etc.... , on down the wall . Every bin is labeled with size and length . KISS , keeps it simple for Me , ( the second " S " , = stupid ) :thumbsup: . When a bin is getting low , easy to see , pick up a box or a 1/2 pound , depends on were I go in town as to how the sell . Rarely get grade 8 , not much use for a whole selection , thus buy as I need . Metric , heh , about the same as grade 8 . Have a container with small compartments that I use for metric , most are small machine type bolts , etc... .
My son wanted to change my bolt stuff around 1 day and I kind of blew up . Better half took the brunt of that tirade . Being that I am on the road 5 to 5.5 days a week , I rely on Her to keep him inline and not jack stuff up . He wanted to put bolt selection in those plastic drawers setup's . I made it clear if I wanted them in plasic drawers , I would of had those in the first place . 30+ years I have set up my shop how I want it , not how he wants it . My Shop , My rules . :cool: ( Oh and He no longer leaves my new welding helmet laying around either , in fact think he no longer uses it , uses the old helmet :thumbsup: )
Fred H.
/ Harbor Freight Tools that don't suck #8,108
You tell him Fred. Darn kids!
BTW the town you're from is my last name. Coincidence.
/ Harbor Freight Tools that don't suck #8,109
Fred H.
Yeah as a city boy who has moved to the country I am just learning this stuff. Getting the shop set up the way I want is a learning experience.
/ Harbor Freight Tools that don't suck #8,110
Harbor freight 12 ton stands for fixing flats. They are a good height. IMG_1058.JPG
12 Ton Jack Stands
/ Harbor Freight Tools that don't suck #8,111
/ Harbor Freight Tools that don't suck #8,112
I'd rather go with plastic jars or metal cans than glass...a lot less hazardous when ol' butterfingers drops one. :(
Harbor freight 12 ton stands for fixing flats. They are a good height.View attachment 529951
Don't worry, it's only flat on the bottom. :D
/ Harbor Freight Tools that don't suck #8,113
I bought two of the 30 bin racks when they were on sale for $15, but have yet to mount them. Gotta clear up some wall space. They'll be used mostly for all those 1lb boxes of trim screws, deck screws, Tapcons, etc.. All my screws/bolts/nuts/washers go in clear plastic jars (mayo, pickle). One jar for each type (machine, countersunk wood, pan head, etc.).
Then, a couple of THESE -
are indispensable for dumping out the jars to find exactly what's needed.
/ Harbor Freight Tools that don't suck #8,115
Yes! Those are indispensable. Can hardly dispense without them! :)
Really, one of the handiest products that HF sells.
What do you call them? They do look handy.
/ Harbor Freight Tools that don't suck #8,116
3 Bin Wall Mount Parts Rack
Anyone use the above? I am just a homeowner, not a commercial repair guy. Building up the usual assortment of nuts, bolts, screws and whatsits from projects. Like to keep the left overs organized so when the next project comes along I don't have to run to the hardware store.
So I do not need anything too beefy, it will get some occasional use.
I've two and use them primarily for nuts, bolts, washers etc.
Checking hfqpdb they often have a coupon for $14 http://www.hfqpdb.com/coupons/329_ITEM_30_BIN_WALL_MOUNT_PARTS_RACK_1506754480.3502.png
/ Harbor Freight Tools that don't suck #8,117
And note that the 1"x 30" BELT SANDER has a coupon for $40. This is an excellent sander for sharpening knives.
/ Harbor Freight Tools that don't suck #8,118
HF Funnel tray. $2.99
530011d1511909946t-harbor-freight-tools-dont-suck-image_17574-jpg
Highly recommended! These are ideal to dump out a random mix, say nuts/bolts/washers of one size - to find the one lockwasher you know was in there, and then pour everything back into the container.
/ Harbor Freight Tools that don't suck #8,119
Can't believe I've never seen them either. How handy would they "had been".
/ Harbor Freight Tools that don't suck #8,120
i use an old square steel cake pan with one corner cut off.
Bruce
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
FONTAINE SPECIALIZED LOWBOY (A60736)
FONTAINE...
2018 Jayco 264BH 29ft. T/A Travel Trailer (A61569)
2018 Jayco 264BH...
2004 JOHN DEERE 624J WHEEL LOADER (A62129)
2004 JOHN DEERE...
2005 International 7600 Dump Truck, VIN # 1HTWYAHT15J055083 (A61165)
2005 International...
2009 Menzi Muck A91E 4x4 Spider Walking Mobile Hydraulic Excavator (A61567)
2009 Menzi Muck...
