/ Harbor Freight Tools that don't suck #8,062
/ Harbor Freight Tools that don't suck #8,063
No, the saw takes a bigger blade.
No markings tell me what size it is but I'd guess (without measuring an old blade) that it is a 9". (They made 8, 9 & 10 inch for a short time.)
Also a Sears-Craftsman, inherited from ex F-I-L. Late 50's early 60's vintage.
The 7 1/4 just barley gets down to the table but did cross cut the pipe.
If I was trying to rip sheet stock, I would put a shim under it, something like a piece of paneling or plywood.
P.S. Wear protection, eye, face, & anything else the CHIPS can get at. They are sharp & hot.
Metal Saw - YouTube
Hi LD,
Thanks, I was wondering if that was how you were doing it- I'll have to get one of those blades.
Thanks also for the reminder about safe practices- I'm almost always scrupulous about those things- I get a fair amount of practice pulling metal fragments out of corneas at work, AND suturing the digits that got too close to the spinning metal, so a lot of the safety stuff comes naturally any more.
I thought about going along with the recall for the Craftsman saw, but after looking into it, I found out that they don't just want the motor, they require return of the whole carriage it uses to attach to the arm as well [which is good sense on their part as it completely disables the saw], and that would be a shame as I'm happy with the whole thing otherwise- and I'm extremely cautious with any chance of blade contact no matter how I use it.
Thanks again,
PA
/ Harbor Freight Tools that don't suck #8,065
Just bought this 2-ton floor jack. Haven't used it yet. Didn't purchase the extended warranty. Still have 30-days to decide. They did mention with the extended warranty I could upgrade to a larger model and only pay the difference. Thought that was pretty cool.
/ Harbor Freight Tools that don't suck #8,066
That looks exactly like the 1 1/2 ton aluminum jack I have and it has become my go-to jack. I even sold the steel ones. One pump and it's up, it's lightweight and rolls easy. Easy to carry around if I can't roll it and easy to position under vehicle. No more steel jacks for me.
/ Harbor Freight Tools that don't suck #8,067
It's my understanding that the trade-off with the one- or two-pump "racing" jacks is that they require a lot more force per stroke to operate. Have you not found that to be an issue? Although 20 years ago, I don't think I'd have cared!
/ Harbor Freight Tools that don't suck #8,068
Just purchased the 301pc Mechanics Tool Set on sale for $155.
I'd read they were manufactured in Taiwan, so I wanted to check it out. Mine says "Made in China" -- and the fit / finish looks like it.
I'll probably still keep it though.
I have a couple similar sets -- 2 different Craftsman versions (150pc, plus another similar sized), 2x Kirkland / Costco 159pc (very nice finish), and a Dewalt 181pc black chrome.
The problem with the smaller sets is that I always seem to need that 1 tool / bit / socket / wrench that isn't included.
/ Harbor Freight Tools that don't suck #8,069
I bought one of their cement mixers with a 40% off coupon. It's not a Kobalt, but it works fine for one 60# bag at a time. Two overwhelms the motor. Still better than a wheelbarrow
/ Harbor Freight Tools that don't suck #8,070
We have the 3 1/2 cubic foot version. I think it was $189 on sale.
It will do 2x 60lb bags, but I prefer to do them one at a time. I think that's around .45 cubic foot each. I'm happy with it.
Runs off a little 1600w generator.
I dump the mixed concrete directly into the BX2370 bucket, then drive it to the destination and dump / shovel it out.
/ Harbor Freight Tools that don't suck #8,071
I bought that one about 18 months ago, for a project. Decided to upgrade it a bit. The little tires are a joke. I had a couple of bigger tires from a fertilizer spreader I “recycled”.
Made the mixer much easier to move around.
/ Harbor Freight Tools that don't suck #8,072
/ Harbor Freight Tools that don't suck #8,076
/ Harbor Freight Tools that don't suck #8,077
Can anyone comment on this 1 1/2 ton aluminum jack? It's $60 tomorrow and that's as cheap as I've seen it.
1.5 Ton Aluminum Racing Floor Jack with Rapid Pump(R)
I personally don't like the "rapid pump" floor jacks. I have never done a NASCAR pit stop so I have never needed to jack a car up in less than 3 pumps. The extra force needed to raise it that quickly isn't usually a problem but when you are trying to position something and are using one hand to steady/ guide it into place and the other to pump the jack up that extra force is annoying. But trying to maneuver a steel floor jack that weighs more than twice the aluminum jack also is annoying. For $60, I probably would buy one too if I didn't upgrade to a 2 post lift.
Red Cedar Glider Chair (A61569)
Red Cedar Glider...
1770 (A58375)
1770 (A58375)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
MAHINDRA 4540 TRACTOR (A62130)
MAHINDRA 4540...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 DRAGON 130BBL STEEL (A60736)
2007 DRAGON 130BBL...
