Replace 1156LL head light with LED
/ Replace 1156LL head light with LED #21
Thank you for the last few replies- I thought the sockets were wired backwards from what is normal. There are no spades at the socket and I haven't figured out how to unplug the harness to see if I can reverse it there. If you look at the first picture you can see the connector. Is it worth bothering to try to figure out how to disconnect it to see if I can reverse polarity there or should I just snip the feed wires and swap them there?
Before cutting wires I would first try the instructions I added below to your first pic, tab to push pointed at by red arrow on left socket then separation instructions on right socket. Looking at your picture it should work but have no idea if it will expose terminals that are swappable.
Thanks, I'll give it a try.
/ Replace 1156LL head light with LED #24
I tried to get the wires out of the connector first and couldn't get them to go. I figured rather than messing up the socket I'll just snip the wires. I swapped them and put them back together with weatherproof butt connectors. They should be good now.
CAT 315CL 42" Bucket (A68134)
CAT 315CL 42"...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
REYNOLDS 14C SCRAPER (A67714)
REYNOLDS 14C...
2000 Hino (A64194)
2000 Hino (A64194)
2019 Nissan Sentra Sedan (A66738)
2019 Nissan Sentra...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
