UTV Battery Charger
/ UTV Battery Charger #1
Gem99ultra
Elite Member
Mid-Georgia
Kubota L3400HST
I'm thinking that my EZGo 36v battery charger isn't giving me full battery charges. Six Trojan 105 batteries less than a year ago only holding for about 2 miles of driving.
Can those batteries be charged with my Schumacher super duper $100 "12V" battery charger? Or, are there any other suggestions?
/ UTV Battery Charger #2
yes, you sure can use a general automotive charger like that one, put the charger across 2 at a time (2 in series for 12V) - a 12V battery is 6 cells in series, so 2 6V is still 6 cells in series.
You're more likely suffering from battery sulfation, so if you have one (a charger with a de-sulfation mode) use it - may require multiple cycles. The biggest killer of storage deep cycle batteries is using but neglecting IMMEDIATE recharge - sulfides occur when the state of discharge is left with out recharge. I use a lot of storage deep cycle batteries in marine use, and am adamant about recharge AS SOON as possible after use, and I've got grp31 batteries going on 5 years of service and still STRONG.
Some technical info, fully charge your cells, measure the open terminal voltage after they set for 30 minutes post charge (disconnect charger and everything else) and they should be roughly 6.3V per cell or better. also, on the charger, just prior to the charger finishing, they should measure about 6.9V to 7.2V per cell (what is called float/finish charge mode), when you first attach the charger after generous discharge, they may read as high as 7.7V or slightly more (what is called bulk charge mode). Hopefully your EZGo charger is a 'automatic multi-stage charger, if not you need to change out to one that is like what is used in the marine world, most are multi-bank of 12V, so you'd charge 1 pair of cells (12V pair) off of each bank. There are models that go as high as 20Amp per bank, which is generally adequate for those cells.
Excellent info frugalangler... thanks.
I'm getting 6.3v after charging, but quickly dropping to 5.8/5.9 after only few minutes of use. Would that indicate a dead cell in one or more of the batteries?
/ UTV Battery Charger #4
That could indicate a dead or dying cell. You really need to check the "resting" voltage: charge fully, then disconnect the charger overnight and check the next morning. If the battery is heavily sulfated, that can drain the battery. If your Shumacher charger has a desulfation mode, you may be able to recover the battery by leaving it connected for an extended period (sometimes a week or more), but you need to make sure your charger has a "maintenance mode" that will not overcharge the battery.
/ UTV Battery Charger #5
Have you been adding distilled water to them?
2014 KENWORTH T370 ROAD TRACTOR (A62130)
2014 KENWORTH T370...
FERGUSON 21 (2) ROW PLANTER (A62130)
FERGUSON 21 (2)...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A62129)
CATERPILLAR 631E...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
