Good morning!!!!
   / Good morning!!!! #64,582
I’m not spending that much time on my turkey! LOL
Kyle, I hope your son is on the mend quickly.
   / Good morning!!!! #64,583
Gawd, in 5 years I’ll be almost 76, hope I can still eat turkey
   / Good morning!!!! #64,585
I’m glad to share the 24 hour process with you .... just to speed things up.
In all seriousness (yeah right) we really like the Alton Brown baking method as well. 500 degrees for 30 minutes then 350 degrees until measured temperature is met on internal probe.
Mmmmm Mmmm Goood!
I learned a similar method for prime rib. I’ll have to look it up but, put PR in oven at 500 degrees with inserted temp probe. Turn off oven after about 30 minutes, leaving oven door closed until internal PR temp gets to doneness you prefer. If anyone is interested I’ll look it up and share?
   / Good morning!!!! #64,587
Loaded my 50 HP Tractor on my gooseneck trailer on Monday and broke thru a deck board doing so. The cross bracing is on 16” centers so, no issue.
Decided today to remove the entire deck and replace same with new grade 1 PT 2 x 8’s. This trailer is about 11 years old so, not unexpected that the original deck boards were failing. Doubt if they were even grade 2.
The original deck boards were secured to cross bracing with 2 1/2”screws with non-coated Torx head screws. They are kind you must pre-drill hole for each screw.
I’m looking for ideas on coated #12 x 2 1/2” self tapping screws, Torx Head, similar to the TEKS Coated screws.
Thanks!
   / Good morning!!!! #64,588
Loaded my 50 HP Tractor on my gooseneck trailer on Monday and broke thru a deck board doing so. The cross bracing is on 16 centers so, no issue.
Decided today to remove the entire deck and replace same with new grade 1 PT 2 x 8痴. This trailer is about 11 years old so, not unexpected that the original deck boards were failing. Doubt if they were even grade 2.
The original deck boards were secured to cross bracing with 2 1/2敗crews with non-coated Torx head screws. They are kind you must pre-drill hole for each screw.
I知 looking for ideas on coated #12 x 2 1/2 self tapping screws, Torx Head, similar to the TEKS Coated screws.
Thanks!
Consider pre drilling and using stainless carriage bolts with poly lock nuts on the bottom.
McMaster-Carr
   / Good morning!!!! #64,589
McMaster-Carr
Thanks Kyle. Pre-drilling and crawling around under trailer, is the step I’d like to avoid. McCoys has some ceramic coated self drilling trailer deck screws but ...they are Phillips head screws. I consider them fair to install, terrible to remove in 10 years. I know there has to be similar coated screws with Torx heads?
The original screws, on this trailer were rusted but, a few (maybe 1/2) could be removed with impact driver and Torx bit. Some just broke off. On others the head was badly rusted and bit just spun.
Will be grinding off the screws I couldn’t remove or broke, manana.
   / Good morning!!!! #64,590
Good evening all. 56F this morning, overcast, calm wind. Wind stayed light today, overcast thinned a bit today, and high temp made it to 69F. This morning did some chainsaw work, had 3 small trees (3-6 in dia) to take down and haul off. Subdivision is have a brush haul off weekend, so loaded up the trees, and some branches we trimmed 2 weeks ago and there were guys to unload me when I got there :). Decided to ride today in light as opposed to tomorrow and 20+ mph winds. Sat. wind forecast are as bad, but get out of 1 day day of bad wind.
   / Good morning!!!! #64,591
2017-11-17, 0341
34 right now...and that's about where it's going to stay today...
   / Good morning!!!! #64,592
Good morning, the sun is shining and the "random" animal inspector that was due to come and check that every ewe out of a sample of 60 all have functional RFID tags in their ears (otherwise we get a fine) has cancelled, so things are looking about as good as it gets.
I gotta go to the butchers today, so I will have to bite the bullet and pay out $1.239/Litre of gas. That works out not including exchange to $4.68/US gallon. YUK!
LFN, I was about to sympathise with you as I also filled up this week at 1.23 per litre. Then I realised I pay in English pounds, so in dollars that's $1.62 per litre ($6.13 /US gallon). Hope that makes you feel a little better - I changed to a petrol/electric hybrid last year to save me bending over so often. :)
Ed, how are you getting on with your Toyota hybrid ? I still smile each time I go down a hill and realise I'm recharging the batteries instead of wearing down the brakes.
   / Good morning!!!! #64,593
Good Morning.
17 and going to a high of 27. Mostly cloudy, wind NNW 8mph.
Eric, she took exactly 60 L of regular at $1.239/L minus a $0.05/L coupon.
I had trouble with the fuel tank a couple of years ago and opted for a 94 L tank. So at 60L I still have a 3rd of a tank left. The upside is that I have more flexibility about where I fuel. The downside is that it is expensive when I do fuel up.
In a vehicle with good compression, one shouldn't need to 'ride the brakes' going down hills. Just pick a lower gear.
   / Good morning!!!! #64,594
35 high of 58 later today big cold front goes thru tomorrow afternoon
   / Good morning!!!! #64,595
Good morning all, 32 going to 54 and sunny. Back is still tight this morning but loosened up fairly good yesterday, hope it is a trend. Got the dust collector remote working yesterday and just did the required stuff. Today will likely be about the same.
Kyle, Hope and pray that your boy is well and back to normal.
Eric, Thanks for the pic's. The Toyota is doing great, we get .10 off a gal for every $100 we spend at the grocery. Right now I have .70 cent off a gallon and still have 3/4 of a tank. :D That makes me happy. A few mounts ago I got gas for 70 something cents a gal.
Have a great day. Ed
   / Good morning!!!! #64,596
Need to pour first cup of coffee. 32° with cloudy skies this morning. Heading to 42° with mostly cloudy skies. Eary morning doctor appointment today. With stops at Menard's and Sams Club. Then back home and work on winterizing garden pond. Started checking out speed reducer project. Next thing I know it's done and working good. All other projects are still waiting. La Crosse weather station is working great. App is not. Maybe they will get it working in a few years.
Rick, consider square drive screws. Our Canadian neighbors call them Robertson drive screws. Other than time consuming. I would pre-drill and tap all the holes. Then put anti-seize on all the screws when installed. You will need good quality galvanized screws for treated wood.
Eric, over $6.00 a gallon for gas. Will not take long to pay for that HYBRID.
Good Morning All.
   / Good morning!!!! #64,597
Ed, hope the back improves quickly, Kyle, hope the boy is better.
Around 40 this morning, 50’s and very windy today, wind through the weekend with 45 mph gusts Saturday night.
Got another letter from SS yesterday saying my benefit would go up about 40%. I’m confused!
I’ve had a couple of rough days, especially yesterday, spent a lot of time hugging her sweater. I know it’ll get better someday.
   / Good morning!!!! #64,598
Ah, those were the days ... Now many of our cars have been made more fuel efficient, engine breaking is almost getting to be a thing of the past. My wife's car isn't a hybrid and coming down the track to our house with the CVT in "M1", it still needs a good brake-devouring push on the pedal to save flying off over the fence
   / Good morning!!!! #64,599
33F now couple more degrees will be the day high.
Winds are huffing and puffing now thru most of the day,fingers cross rest off leaves pine cones will fall for finally clean up tomorrow.
Friday...be long week.
Enjoy the day all.
   / Good morning!!!! #64,600
30 frosty and clear going to 56.
Kyle, I hope your guy is feeling better today.
Rick, sounds like you're doing a really good job on the trailer, so hopefully you won't have to repeat in 10 years.
Took advantage of the nice 63 degrees day yesterday to wash 28 windows. Only did the outside, so the hard part is still due - inside. Plus, have more windows to do outside. The cold weather has alerted me to how old and stiff my hoses are getting (and my body on some days)...need new ones by spring. I think I've read threads on "best" garden hoses, but does anyone have a favorite?
Toro MBTX-2500 Concrete Buggy (A54865)
Toro MBTX-2500...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
