Anyone with experience with Bobcat B300 TLB.
   / Anyone with experience with Bobcat B300 TLB. #21
Did you figure out when your axle is locked and when it's not yet? I sold my B300 quite a while ago and went to tractor loader backhoe with removable hoe.
I just got back from a trip. Thanks for replying. I haven't totally figured it out yet. Haven't had the time. Looking at the manual it shows that the rear axle is the "lock up" axle. Pushing the console button activates a solenoid/cylinder actuator that is suppose to move a fork inside the rear axle to lock it up. With the fuse box removed I can see the actuator under the seat try to go in when I push the momentary button on the console but it only moves a fraction of an inch. It kind of tells me the fork is not moving in to actually lock anything up. I haven't got farther than that yet. I'll have to study the operation of that a little more and see if there may be an axle "lock up" issue.
Did you find the steering a little tough on dry pavement? It always seems as if I am fighting a mechanical type of lockup if I turn too tight and then want to bring it back. On soft ground there is no problem. Everything else seems to run fine. Nice strong machine. It's just a play toy for me. I am an engineer by trade and would like to figure it all out. LOL
I live in the country and never had mine on pavement or concrete. I remember the steering went a little off and there was a way to adjust it to bring it back into the correct line up. But it has been several years since I sold it now and I can't even remember how I did it! LOL C.R.S.
Very strong machine for its size. I got a lot of heavy duty work done with it. Really enjoyed it.
   / Anyone with experience with Bobcat B300 TLB. #23
It is really strong. It will do what I want. The wheel alignment was pretty simple. Just raise the machine, open the steering alignment valve and set each axle.
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
TANK MANIFOLD (A55745)
KOMATSU WA380-8 WHEEL LOADER (A60429)
KOMATSU WA380-8...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2015 Freightliner 122SD T/A Day Cab Truck Tractor (A60460)
2015 Freightliner...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
