Clean light bar on ROPS?
/ Clean light bar on ROPS? #1
cold1313
Gold Member
Northern, Ohio
Kubota M4D-071 Kubota F3990
I was wondering how you all have made a bar to attach to the ROPS, to mount your lights on? I need something that will tuck in the ROPS so that when I brush against a tree limb, the limb goes against the ROPs and doesn't hit the lights.
Curious to see what people made and how their attaching to the ROPS. My current is just some angle iron, nothing fancy. Looking for a cleaner setup.
/ Clean light bar on ROPS? #2
i used an idea from another member. I bought a couple of 75 or 95 lb magnets from HD and attached the light bar to them and placed under the top of the rops. holds on tight.
/ Clean light bar on ROPS? #4
Yeah, it is. I saw it when I was reading about LEDs on this site. Another member did this and i tried it. IT works great. It really has to be hit with some force to get it to come off or even move. the magnet has to sit flat on the roll bar and it holds on real tight. LEDs compared to factory lights is like night and day. IMG_0902.JPGIMG_0901.JPG one pic is factory lights only. other is 120W led light bar spot/flood combo.
I just remembered there are some branches that would push in between the ROPS bars and would probably knock that off. I was going to take some angle iron or square stock and make almost a brush guard for it also.
the metal is free...just looking for ideas on how to hold onto the ROPS
/ Clean light bar on ROPS? #9
I drilled and tapped mine into the rops just using sheet metal screws. Nice and easy but a good idea to dab a little paint after drilling just to cover the bare metal.
/ Clean light bar on ROPS? #10
I mounted my lights to a random chunk of square tubing. I then used some U bolts to strap that square stock to the ROPS. Made some hockey puck spacers out of PVC pipe to give clearance between the bottom of the brackets & the ROPS.
Got things mounted without modifying the ROPS.
/ Clean light bar on ROPS? #11
/ Clean light bar on ROPS? #12
I dont think a small hole in the flat would hurt. Something like 1/4 or 3/8 but would not drill anything like a 1/2.
I'm personally avoiding any modification to the ROPS. By drilling into it, I'm 99.9% sure that Kubota is not liable for any injuries if the ROPS fails because it has now been modified.
Will a small hole make a difference in strength? I don't think so. Is Kubota legally off the hook? Yes.
/ Clean light bar on ROPS? #14
I made brackets to use existing holes to mount to ROPS. Actually on the front I attached to my canopy frame. Prior to getting the canopy, I had planned on mounting both forward and rearward light bars to the same mounting plate that I currently use for the rearward facing bar. Overview on my YouTube channel.
John Deere 4066R LED Light Bar Installation - YouTube
/ Clean light bar on ROPS? #16
Ive got a bar awaiting mounting on the ROPS. I'd planned on mounting it on the bottom side and just using stainless hose clamps for the mounting.
/ Clean light bar on ROPS? #17
For those of you who have mounted a light bar on the roll bar does it blind you when looking backwards?
/ Clean light bar on ROPS? #18
Not for me... on my BX I mounted two facing fwd and two to the rear. They are above and slightly behind my head so I don't really see them looking back. But I do usually have a baseball cap on that likely blocks any glare or stray light.
/ Clean light bar on ROPS? #19
Make sure you always wear your seatbelt as well, Kubota would be off the hook legally if you are found not wearing the seatbelt.
A small hole was drilled into my rops for light mounting and wasn’t concerned about a tiny hole weakening the structure at all.
In addition, ROPS only “works” if wearing a seatbelt. If you don’t wear the belt, you may as well remove the ROPS, but it’s useful for mounting the lights on so May as well keep it installed.
/ Clean light bar on ROPS? #20
That's what I did. It was designed for an automobile (long mounting bolts) so I cut a steel bar, drilled the holes, bolted it on with the provided locking nuts (at a guestimated 'down' angle)and cut the excess bolt away. Next, a thick piece of rubber matting between the bar/nuts and the underside of the ROPS. The rubber matting eliminated vibration.
I used tie-wraps (zip-ties?) to position it and then secured the whole thing with a couple of stainless hose clamps. I cushioned the clamps on the ROPS using a cut-up foam-neoprene 'stubbie holder' (koozie?).
Wire was run down the back edge of the ROPS.
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
UNUSED WOLVERINE MAD-12-12D 12" MINI HYD AUGER (A62131)
UNUSED WOLVERINE...
2024 John Deere 835M Gator (A63116)
2024 John Deere...
2015 Audi A4 Sedan (A61568)
2015 Audi A4 Sedan...
2023 John Deere Z930M Zero Turn (A63116)
2023 John Deere...
