arto98607
- Joined
- Aug 27, 2014
- Messages
- 1,667
- Location
- Southwest WA
- Tractor
- Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
.... A couple of points about the recommendation from arto98607. The wheels he linked too are the right size, but they are white instead of orange (if that matters to you). Also the axle for the wheels would take a fair amount of work to make. I have a lathe and welder and I could make the axle from drill rod as arto98607 suggests, but new axles were $40 each on eBay and my time is worth more than that if I were to make them myself. They are not simple:
OK I understand.
There is a noticable difference in the design!
My F3060 has a rear discharge deck (RC72R-F30) with very simple axle shafts of straight 3/4 inch "rods" with 5/32" cotter pin holes drilled at each end.
Photos before any cleaning of mud etc.
The old tires are Marathon Flat-Free 9 x 3.50 - 4 inch wide solid rubber tires, with few big chunks of tire rubber missing - however they could still be used but look pretty ugly.
I am in the process of installing a new replacement deck shell and rebuilding or repairing anything that's worn out.
This is a 3500 hour ex. municipal mower where the deck was simply operated too close to the ground (in my opinion), which caused lot of wear in the deck parts. The deck wore out but the good news is the rest of the mower was serviced regularly and is in good shape!
:ambulance:
