Need some ideas.
/ Need some ideas. #1
GrumpyJoe
Felicity, Ohio
Mahindra 1533 HST w/ FEL
Maybe you guys can help me. Looking to build something to help lift firewood up onto my splitter. Back is not as good as it used to be. Usually, after a few hours lifting logs up onto the splitter, my back is done for a few days. Looking to build something like a tri-pod with a swivel head and bar on top to lift. Any ideas? Or know of something out there already?
/ Need some ideas. #2
Pictures of your splitter? A adding a log lift would be the most convenient IMO.
/ Need some ideas. #3
What's wrong with your FEL ?...build an narrow bench that you can set the loaded bucket down on on one end and be close enough to roll rounds directly onto the splitter from the other end...That is what I did before I built a hydraulic lift...
I used a boom pole and log tongs for really big rounds...
[Edit]
Just realized it may be a 3PH splitter...oops if so...disregard...
[/Edit]
Good Luck...
/ Need some ideas. #6
I made a 4'x5' heavy duty pallet and use that. I use my forks and take it to the pile of cut rounds and put it on the ground next to them. I roll heavier rounds onto the pallet and ones I can lift easily I just lift them.
Then I took a saw horse and cut the legs off to the right height and set the pallet of rounds on top of the pallet right next to the ram. Cut the pallet so the top of the pallet is even with the top of the Log lift.jpgsplitter beam.
I position the pallet about 2" from the beam. Then I just reach over and roll them onto the beam and split them. I use the same pallet to lay the opposite side of the split onto it until I get the close half of the round split.
I started doing this about 3 years ago and it works super. I never lift heavy rounds now because I can roll them up onto a pallet. That works for 30" and smaller.
Larger rounds I might stand the splitter up, maybe.
/ Need some ideas. #7
Yep. And most productive. If the splitter is hydraulic driven then it has the ability to run a log lift.
/ Need some ideas. #9
Then I took a saw horse and cut the legs off to the right height and set the pallet of rounds on top of the pallet right next to the ram. Cut the pallet so the top of the pallet is even with the top of the View attachment 528075splitter beam.
Simple, easy to build, and will work well.
/ Need some ideas. #10
I can’t lift that much either, hydraulic log lifters are too slow.
If I have to roll them around anyway I just get a pair of knee pads and flip the machine vertical. That way I never have to lift any wood until it’s split into smaller pieces. When I can’t do that anymore, it won’t matter because I couldn’t pick them up to burn anyway.
/ Need some ideas. #11
Found this. Home - Gorillabac Anyone know anything about this company?
It would certainly lift the round up to the splitter if your time isn't of concern and it looks to be more labor intensive to get the end result.
Deere Dude's solution is simple, cost effective and a back saver. I use the same principle as his and it works well.
/ Need some ideas. #12
...hydraulic log lifters are too slow....
If I remove the restrictor and don't feather the lever...my lift will toss a 200# round over the top of my splitter in a heartbeat...!
/ Need some ideas. #13
I can稚 lift that much either, hydraulic log lifters are too slow.
If I have to roll them around anyway I just get a pair of knee pads and flip the machine vertical. That way I never have to lift any wood until it痴 split into smaller pieces. When I can稚 do that anymore, it won稚 matter because I couldn稚 pick them up to burn anyway.
Not sure why you would think a log lifter is too slow.
Especially when you are willing to get on your knees on the ground and then have to pick the splits up to load.
Large Metal Bull Smoker (A61569)
Large Metal Bull...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2019 GENIE S-60XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-60XC...
New/Unused Landhonor Adjustable Gantry Crane (A61166)
New/Unused...
2007 BMW 3 Series 328i Sedan (A61569)
2007 BMW 3 Series...
Pallet of Forklift Safety Basket (A61567)
Pallet of Forklift...
