Installed new headlights
/ Installed new headlights #1
4get gto
Elite Member
N.E. Pa.
Yanmar 147D with loader,Woods mow,n machine 6210 ,Sears st10,Roper rt 10
Always the guy to improve on something and not being able to see that well at nite when plowing snow I add some led's. So I went from this IMG_20171105_151929.jpg to this IMG_20171105_152001.jpg.
Turned out pretty well I think.
/ Installed new headlights #2
Did you just install a wire mesh behind the holes and then bolt the lights to it?
Actually the wire mesh is there only to fill the gaps. Used the existing mounting
bracket the old lights were mounted to. Was a little challenge finding a light that would be close to fitting. Big difference from the original hi/low beam bulbs. They weren't much more than a brake light bulb. Had to fabricate some new brackets but wasn't too hard. Cost about 16 bucks.
/ Installed new headlights #4
Yea those headlights now are not very bright, like you said basically like an 1157 bulb. I keep saying I will do this, but I like the factory look and I seldom do any work ag night so I never follow through.
2019 VOLVO A45G OFF ROAD DUMP TRUCK (A65053)
2019 VOLVO A45G...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
1980 Gleaner F2 with heads (A61307)
1980 Gleaner F2...
4022CFL (A59228)
4022CFL (A59228)
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
