Watery chainsaw fuel
/ Watery chainsaw fuel #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
How do you dispose of cainsaw fuel that has water in it?
/ Watery chainsaw fuel #2
I've disposed of old chainsaw fuel by pouring it( less than two gallons ) in an open five gallon pail and just letting it evaporate. I tried separating the water out with one of those "water separating" funnels - it didn't work well, the oil in the chainsaw fuel mix sort of gummed things up.
/ Watery chainsaw fuel #3
Yep, evaporation, but out in the shed not inthe garage.
/ Watery chainsaw fuel #6
Bucket of sand & a match.
Matches and gasoline doesn't sound like a good idea, but what's the process? Does this work? Does the sand act like a slow wick for the fumes? Ratio of sand to gas?
Don't the fumes just explode when you approach with a match?
/ Watery chainsaw fuel #8
A 5 gallon steel bucket will contain the fumes pretty well especially on a very cold day. Then stand upwind and toss a match at it, it may take several tries to get the match to the right location where the gas/air mixture is ok for a burn.
/ Watery chainsaw fuel #10
I keep lidded 5 gallon buckets that hold primarily waste oil. Any waste gas also gets dumped in. Then I burn it on brush piles.
Thanks to everyone for the suggestions. I think Moss Road might be on to something.
/ Watery chainsaw fuel #12
How much water are we talking vs how much fuel? You should be able to decant the fuel off the top down to a cupful or so. The water will stay in the can. Of course don't shake the can first as we all apparently do....
/ Watery chainsaw fuel #14
I also keep a lidded 5 gallon bucket of waste oil and old chainsaw gas around for lighting brush piles. If there is too much gas in the mix, I stand back about 20 feet and use 4th of July bottle rockets to ignite the pile.
/ Watery chainsaw fuel #15
Well, a bucket of sand and don't fill over the level of sand. Let it sit for a bit, stand upwind and throw a match. You can make a sorta fuse by dribbling gas in a line away from the bucket and then throwing a match. If you've spilled gas on yourself or clothes don't strike a match.
Even better, bury the bucket in dirt. Then you can easily heat an item over it.
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
UNUSED WOLVERINE HYD GRAPPLE BUCKET (A64281)
UNUSED WOLVERINE...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2005 Freightliner M2 106 20ft. Reefer Box Truck (A61573)
2005 Freightliner...
2018 Dodge Charger Sedan (A61574)
2018 Dodge Charger...
