Watery chainsaw fuel
/ Watery chainsaw fuel #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
How do you dispose of cainsaw fuel that has water in it?
/ Watery chainsaw fuel #2
I've disposed of old chainsaw fuel by pouring it( less than two gallons ) in an open five gallon pail and just letting it evaporate. I tried separating the water out with one of those "water separating" funnels - it didn't work well, the oil in the chainsaw fuel mix sort of gummed things up.
/ Watery chainsaw fuel #3
Yep, evaporation, but out in the shed not inthe garage.
/ Watery chainsaw fuel #6
Bucket of sand & a match.
Matches and gasoline doesn't sound like a good idea, but what's the process? Does this work? Does the sand act like a slow wick for the fumes? Ratio of sand to gas?
Don't the fumes just explode when you approach with a match?
/ Watery chainsaw fuel #8
A 5 gallon steel bucket will contain the fumes pretty well especially on a very cold day. Then stand upwind and toss a match at it, it may take several tries to get the match to the right location where the gas/air mixture is ok for a burn.
/ Watery chainsaw fuel #10
I keep lidded 5 gallon buckets that hold primarily waste oil. Any waste gas also gets dumped in. Then I burn it on brush piles.
Thanks to everyone for the suggestions. I think Moss Road might be on to something.
/ Watery chainsaw fuel #12
How much water are we talking vs how much fuel? You should be able to decant the fuel off the top down to a cupful or so. The water will stay in the can. Of course don't shake the can first as we all apparently do....
/ Watery chainsaw fuel #14
I also keep a lidded 5 gallon bucket of waste oil and old chainsaw gas around for lighting brush piles. If there is too much gas in the mix, I stand back about 20 feet and use 4th of July bottle rockets to ignite the pile.
/ Watery chainsaw fuel #15
Well, a bucket of sand and don't fill over the level of sand. Let it sit for a bit, stand upwind and throw a match. You can make a sorta fuse by dribbling gas in a line away from the bucket and then throwing a match. If you've spilled gas on yourself or clothes don't strike a match.
Even better, bury the bucket in dirt. Then you can easily heat an item over it.
(2) UNUSED 15X19.5 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 15X19.5...
1043 (A60430)
1043 (A60430)
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
3147 (A63117)
3147 (A63117)
