CT225 LIFT POWER
/ CT225 LIFT POWER #1
BobcatTR
Decatur, IL.
Bobcat CT225
I thought my Lil 225 was good for 1400lbs, lifting.
Figured just going 200lbs more she'd lift a round bale of hay off my trailer, NOT HAPPENING!
I've always bought 800 lbs. But farmer is going scared selling to much because he has cattle. We went in drought this summer.
So my neighbor only bales 1600lb ers.
Thought I'd try.
Just did the rolling thing!
Always heard next model up 230 was much stronger.
Heck my old 48 8n picked up 1600.
Just couldn't drive anywhere.
I'm on a slope.
Oh well, live and learn!
TR
/ CT225 LIFT POWER #2
The 230 & 235 have the same 7TL loader and hydraulic system as the 225 so no difference in lift capability.
/ CT225 LIFT POWER #3
Might have to go with a 3 point bale spear. It should do it.
/ CT225 LIFT POWER #5
It's amazing what these little tractors will lift. I have definitely put mine to the limit.
If you run your throttle too full you get maximum lift capacity.
/ CT225 LIFT POWER #6
I was able to get a 1800 pound antenna off the ground about a foot with my forks on lifting very close to the loader arms.
My forks are the lighter weight ones not the heavy bobcat ones.
But it didn't like it.
/ CT225 LIFT POWER
Wow, I just ran to the RED dot on the rpms. Did not try full throttle. Duh!
Next bale I will go FULL THROTTLE!
Thanks for that tip!
/ CT225 LIFT POWER
Nice, I'll throttle it up!
I just ran it to the RED dot on RPM'S.
Thanks for the tip
/ CT225 LIFT POWER #9
Hmmm, relief valve should relieve even at lower rpm. At least that is my opinion. That is what should have control over how much you can lift.
/ CT225 LIFT POWER
Yes, I didn't think of That! I do believe you are right!
Theirs might be set higher.
/ CT225 LIFT POWER #11
I know my DK 35 loader will hit the relief valve just over idle if I try to lift to heavy.
Raising the RPM's higher makes little to no difference in lifting power.
/ CT225 LIFT POWER
Makes sense thanks!
/ CT225 LIFT POWER #13
It does not make a huge difference but it does make a difference.
I'm not sure of other tractors but on this one relieve pressure is set using full rpm. Same thing with the hydrostat relief.
The relief valve will still release at lower RPMs just not at the maximum relief pressure. Maximum lift and Hydrostat pressure is achieved only at Full rpm's
/ CT225 LIFT POWER
Keeps from blowing line!
/ CT225 LIFT POWER
I'm not sure of other tractors but on this one relieve pressure is set using full rpm. Same thing with the hydrostat relief. Maximum lift power and hydrostat power is achieved only at max RPM.
Wish I had another 1600 lb bale.
I really want to find out.
Thanks
/ CT225 LIFT POWER #16
Relief valves are set at a pressure to protect your system. Trying to exceed that pressure could be harmful.
/ CT225 LIFT POWER #18
Here's a picture of the loader specs.
I was just thinking there are two different style loaders for these tractors and they're both called 7TL's. The older ones are more of a curve shaped boom the newer ones have more of a sharp angle. The curved ones were made by rhino and the ones with the sharper angle are made by bobcat and are a little stronger according to the spec sheet.
/ CT225 LIFT POWER
That could be a why there's a difference.
I need to check my serial number thank you.
That helps!
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
UNUSED KUBOTA BRUSH GUARD PART (A62130)
UNUSED KUBOTA...
2006 PACE AMERICAN CS714TA2 14' CARGO TRAILER (A62130)
2006 PACE AMERICAN...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
2019 JCB 457 (A60462)
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
