Attaching tool box to ROPS using pre-existing hinge holes?
/ Attaching tool box to ROPS using pre-existing hinge holes? #1
ning
Elite Member
Northern California
Branson 3520h
The ROPS on my tractor (Branson 3520h) has a very convenient hole on each side, probably to hold the ROPS in place when it's folded down.
I never fold my ROPS, and it looks like a really convenient spot to attach a shelf behind the seat, to which I'd attach a toolbox or two.
Any good reason not to use that as an attachment point?
/ Attaching tool box to ROPS using pre-existing hinge holes? #2
No reason what so ever - at least to me. A great place for a tool box.
gg
/ Attaching tool box to ROPS using pre-existing hinge holes? #3
I attached lights to the top of my ROPS by clamping to it so I wouldn't have to drill. It would be just as simple to do the same for a tool box. If you have a hole that works, use it.
/ Attaching tool box to ROPS using pre-existing hinge holes? #4
I used heavy duty aluminum angle material and split the ends to get tabs to bolt to the ROPS. Steel angle would also probably work. I then bolted a standard metal tool box. Just check the top opening clearance on the seat befor bolting it in. To bolt to the ROPS I drill and tapped the holes for the 3/8 bolts.
/ Attaching tool box to ROPS using pre-existing hinge holes? #5
Because it would block visibility. Not sure that really qualifies as a GOOD reason though.
Using OEM mounting points on safety systems is always a good idea compared to drilling your own.
/ Attaching tool box to ROPS using pre-existing hinge holes? #6
That is a very good reason and excellent point!! Visibility is important and you don't want to find out after the fact that you can't see where you need to while running an implement. Mount your box so you can see or make it easily removable. I can remove mine w/o tools when I need to.
gg
/ Attaching tool box to ROPS using pre-existing hinge holes? #7
I use hose clamps to attach an expanded metal safety screen to the ROPS on my 2008 Mahindra 5525. Makes a handy place for a magnetic cup holder also. Don't see why you couldn't use existing holes in your ROPS for attachment.
Good luck
/ Attaching tool box to ROPS using pre-existing hinge holes? #8
I welded a 2x2 hunk of angle between my ROPS just below the folding point and mounted a small toolbox to it. High enough to give me clearance on the fuel cap.
Not a good photo here, since it was the back of the seat being pictured, but you can see one end of the angle with the red tool box mounted to it.
524531d1507853959-another-dadgum-thing-fix-my-dscn5809-1-jpg
/ Attaching tool box to ROPS using pre-existing hinge holes? #9
View attachment 526604View attachment 526605
I thought drilling into ROPS is a BIG no no. Is it ok now?
/ Attaching tool box to ROPS using pre-existing hinge holes? #10
I think it is, from a insurance claim stand point anyway but structurely speaking why would a small hole or two make any difference ?? I can tell you this: I bought a used tractor last spring and received all the maintenance paper work with it. The original owner had the Kubota dealer install 3 work lights. The dealer drilled the ROPS and used self tapping 5/16" bolts. Two in each light. What does that tell you ???
gg
/ Attaching tool box to ROPS using pre-existing hinge holes? #11
Drilling, welding, etc. voids the ROPS liability for the manufacturer. Will a small hole weaken the ROPS - no. Is the manufacturer off the hook for liability should you get injured? Absolutely.
Also, if you modify your ROPS, you can become liable if you sell it to someone and they get injured (seems like a stretch but people have sued over dumber things), or if you trade it to a dealership, they will likely reduce the trade value as they will have to install a new OEM ROPS. All purely due to liability.
Gordon Gould - I'm very surprised a dealer drilled into the ROPS... That could open a can of worms for them.
Messicks just did a quick video to discuss this...
The *WORST MISTAKE* a new tractor owner can make (modding ROPS) - YouTube
It's a very valid point, but on this particular tractor the hinge point is at about elbow height while sitting in the seat, which would place even a large toolbox comfortably outside of viewing range, unless you need to look down at the PTO.
/ Attaching tool box to ROPS using pre-existing hinge holes? #13
Seems everyone is worried about liability, lawsuits and all that good stuff from drilling a small hole in their ROPS. It'd be interesting to know how many of you religiously wear your seatbelt on the ROPS equipped tractors. We all know that ROPS does not protect an operator if they aren't firmly planted (buckled) in their seat.
Drill baby, drill!
/ Attaching tool box to ROPS using pre-existing hinge holes? #14
Drill baby, drill!
:cool2::thumbsup:
I do know that my seat belt is still in pristine condition
2019 Komatsu WA380-8 Articulating Wheel Loader (A64194)
2019 Komatsu...
INSPECTION (A65583)
INSPECTION (A65583)
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
Parker Spreader (A64119)
Parker Spreader...
