Attaching tool box to ROPS using pre-existing hinge holes?
   / Attaching tool box to ROPS using pre-existing hinge holes? #1
ning
Elite Member
Northern California
Branson 3520h
The ROPS on my tractor (Branson 3520h) has a very convenient hole on each side, probably to hold the ROPS in place when it's folded down.
I never fold my ROPS, and it looks like a really convenient spot to attach a shelf behind the seat, to which I'd attach a toolbox or two.
Any good reason not to use that as an attachment point?
   / Attaching tool box to ROPS using pre-existing hinge holes? #2
No reason what so ever - at least to me. A great place for a tool box.
gg
   / Attaching tool box to ROPS using pre-existing hinge holes? #3
I attached lights to the top of my ROPS by clamping to it so I wouldn't have to drill. It would be just as simple to do the same for a tool box. If you have a hole that works, use it.
   / Attaching tool box to ROPS using pre-existing hinge holes? #4
I used heavy duty aluminum angle material and split the ends to get tabs to bolt to the ROPS. Steel angle would also probably work. I then bolted a standard metal tool box. Just check the top opening clearance on the seat befor bolting it in. To bolt to the ROPS I drill and tapped the holes for the 3/8 bolts.
   / Attaching tool box to ROPS using pre-existing hinge holes? #5
Because it would block visibility. Not sure that really qualifies as a GOOD reason though.
Using OEM mounting points on safety systems is always a good idea compared to drilling your own.
   / Attaching tool box to ROPS using pre-existing hinge holes? #6
That is a very good reason and excellent point!! Visibility is important and you don't want to find out after the fact that you can't see where you need to while running an implement. Mount your box so you can see or make it easily removable. I can remove mine w/o tools when I need to.
gg
   / Attaching tool box to ROPS using pre-existing hinge holes? #7
I use hose clamps to attach an expanded metal safety screen to the ROPS on my 2008 Mahindra 5525. Makes a handy place for a magnetic cup holder also. Don't see why you couldn't use existing holes in your ROPS for attachment.
Good luck
   / Attaching tool box to ROPS using pre-existing hinge holes? #8
I welded a 2x2 hunk of angle between my ROPS just below the folding point and mounted a small toolbox to it. High enough to give me clearance on the fuel cap.
Not a good photo here, since it was the back of the seat being pictured, but you can see one end of the angle with the red tool box mounted to it.
524531d1507853959-another-dadgum-thing-fix-my-dscn5809-1-jpg
   / Attaching tool box to ROPS using pre-existing hinge holes? #9
View attachment 526604View attachment 526605
I thought drilling into ROPS is a BIG no no. Is it ok now?
   / Attaching tool box to ROPS using pre-existing hinge holes? #10
I think it is, from a insurance claim stand point anyway but structurely speaking why would a small hole or two make any difference ?? I can tell you this: I bought a used tractor last spring and received all the maintenance paper work with it. The original owner had the Kubota dealer install 3 work lights. The dealer drilled the ROPS and used self tapping 5/16" bolts. Two in each light. What does that tell you ???
gg
JOHN DEERE 4066R (A53084)
JOHN DEERE 4066R...
2018 JLG 3246ES 32ft Electric Scissor Lift (A53421)
2018 JLG 3246ES...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
2018 Freightliner M2 106 Lay Flat Roll Back Truck (A55852)
2018 Freightliner...
Electric Mobility Scooter (A54815)
Electric Mobility...
2023 Kubota RTV-XG850 Sidekick (A55315)
2023 Kubota...
