I Still Hate My Tractor II
   / I Still Hate My Tractor II #361
Please dont quote suspicious posts, the spam removal tools will remove all posts by a user, but will not remove replies which quote the spammer.
Aaron Z
Hey, No need for the thanks, just happy to help. It won't happen again.
   / I Still Hate My Tractor II #362
389 hours, turbo still doing it's job nicely.
Popped a front knuckle seal. Everything is oringed these days so all you need are 2 seals and a cotter pin for the steering tie rod nut.
Lots of metal in each lower front end final drive, there is only one way to get it out and that's to remove the lower seal/plug and drain it out, maybe flush it and refill. Then replace the lower seal plug.
Pix below and NO MORE GD PHOTOBUCKET for me, everything got deleted because I refuse to pay Googles blackmail fee!!!
Regards, Fred
And I do STILL HATE MY TRACTOR! 7 payments left and she goes bye bye.
View attachment 524594View attachment 524595View attachment 524596View attachment 524597
Seals blown at < 400 hrs?
No wonder you hate your tractor... Any extraordinary reason that seal blew at such lo hrs?
   / I Still Hate My Tractor II #363
No seal issues here but I have ripped up my boots. Twice but that was on me... as I was going places I shouldn't have (debris piles) with my BX.
Rust on the sealing surface, I use the machine to blow snow and it gets put away in a heated building to thaw out, dry and that's what happens. I bead blasted the knuckle and painted it nicely. It's an easy job and would happen every few years I'm sure.
From now on I might spray the joints with oil or spray grease as a precaution.
Regards, Fred
   / I Still Hate My Tractor II #365
Regards, Fred
Wouldn't this same problem affect any brand of small tractor?
   / I Still Hate My Tractor II #367
Regards, Fred
Fluid Film!!!
   / I Still Hate My Tractor II #368
Fluid Film!!!
When I restore or detail a tractor that may have been outside for a while or have rusty bolts or parts, I spray a little Fluid Film on the rust and, if stored inside, the problem is gone forever. The metal eventually gets a patina to it and the rust is gone. Great stuff.
So I lied, I still own this turd of a machine. What a crapshow this repair is...... IMGP0217.JPGIMGP0218.JPGIMGP0216.JPGIMGP0215.JPG
   / I Still Hate My Tractor II #370
So what is exactly wrong with it that it needs repaired?
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
TANK MANIFOLD (A58214)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
2003 Big Tex 10PI...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
2019 GALYEAN...
