Rear remotes operation
/ Rear remotes operation #1
rockyridgefarm
Elite Member
NEOklahoma
Yanmar YT347
I must have bumped the remote remote lever up and now it is stuck there. How do I release it? Is it safe to operate the tractor like this? Not much info in the manual.
/ Rear remotes operation #2
It looks like it is just pushed up into Float mode which has a detent to hold it in place just like your loader valve. It won't pull back down?
Correct. It is in float and stuck there. I have nothing that connects to the remotes.
/ Rear remotes operation #4
With nothing being connected, it still should not make a difference, the valve should be able to be pulled back past the detent and spring back to neutral, with or without the tractor running.
It should just pop out of float and back to neutral just like the loader valve does. There is a detent holding it in the float position.
If you can not pull it out of the float position past the detent, then something is in a bind some where.
You can always disconnect the cable at the valve and pull it out of float directly on the valve.
Thanks!!! I’ll try. Do I need to do that before operating the engine?
actually, I was referring to the pump running with the ports disconnected. Will it dead head?
/ Rear remotes operation #8
It should be fine, there is no pressure build up when the valve is in float mode. Now other valves down stream may not work though.
In general I suggest that you get this taken care of sooner than later
It turns out that Yanmar has seen this in at least one other machine.
It cleaned up easily with solvent, with no pitting on the spring. I greased it and it seems to be fine. The upper valve had no issue whatsoever.
Also, Yanmar is fantastic as far as support goes.
/ Rear remotes operation #11
Geez man, what happened there?
This has been sent up the food chain at Yanmar. As I mentioned, I’m not the only one to have this happen. Of course, it looks really strange. No doubt they’ll come up with an answer and it will all make sense. I hope to find out whether the remotes are added in Japan or here in the states.
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
Speed Trailer (A64194)
Marcrest BSP449 (A64127)
Marcrest BSP449...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2004 GMC Sierra Pickup Truck, VIN # 1GTHK23U24F110736 (A65563)
2004 GMC Sierra...
