SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #11
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #13
did somebody replace a hose on the forward reverse selector ? There my be a steelball that got lost without notesing ?
Yes the forward reverse shuttle selector has been replaced with a new one, although it is an electronic control mounted on the left side of the steering column. It is figure #10 part #0.010.6393.4/20 on attached print.
Do you have the Lamb Champion teck manual ?
I don't have that manual, when dealer gets in I'll see if he has it on file. By chance do you have the manual in a Electronic version that you could send me?
Thank you.
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #17
stick is elect....going to a selinoid.....that operates hydraulics.....moving a mech lever inside.
Since I am able to power solenoids using my jumper wires and force tractor to move I think all hard parts are working? I think you are correct that one of the sensors are not grounding to satisfy ECU. I have Deutz distribution here in States trying to pull a manual for a SILVER 110-130 and the LAMB Champ 120-135-150 manual. Do you have the parts breakdown for the LAMB? If so do that model us the ECU #0.010.6393.4/20.
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #20
OK....another thought....you tested all the solinoids that has to get 12v when in gear ? What if you test again and check for solinoids that must not get 12v when in gear ...mybe there is a wire that was burned and giving 12v to something that sould not get 12v ?
2001 CATERPILLAR D400E 6X6 OFF ROAD DUMP TRUCK (A60429)
2001 CATERPILLAR...
2014 Grove TMS700E 60 Ton Hydraulic Truck Crane (A60460)
2014 Grove TMS700E...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Tanker Trailer (A59230)
Tanker Trailer...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
