SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #11
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #13
did somebody replace a hose on the forward reverse selector ? There my be a steelball that got lost without notesing ?
Yes the forward reverse shuttle selector has been replaced with a new one, although it is an electronic control mounted on the left side of the steering column. It is figure #10 part #0.010.6393.4/20 on attached print.
Do you have the Lamb Champion teck manual ?
I don't have that manual, when dealer gets in I'll see if he has it on file. By chance do you have the manual in a Electronic version that you could send me?
Thank you.
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #17
stick is elect....going to a selinoid.....that operates hydraulics.....moving a mech lever inside.
Since I am able to power solenoids using my jumper wires and force tractor to move I think all hard parts are working? I think you are correct that one of the sensors are not grounding to satisfy ECU. I have Deutz distribution here in States trying to pull a manual for a SILVER 110-130 and the LAMB Champ 120-135-150 manual. Do you have the parts breakdown for the LAMB? If so do that model us the ECU #0.010.6393.4/20.
   / SAME Silver 100.6 wont move, (SDF SAME DEUTZ FAHR), please help #20
OK....another thought....you tested all the solinoids that has to get 12v when in gear ? What if you test again and check for solinoids that must not get 12v when in gear ...mybe there is a wire that was burned and giving 12v to something that sould not get 12v ?
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
2020 DRAGON ESP...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
