Hydraulic PTO Conversion
/ Hydraulic PTO Conversion #1
jpmikey
Emmaus
CASE 446
Hello all I'm new in here and would like to know if a gear pump @6 GPM and 2000 PSI would work as a power source for powering a PTO motor. This is for my CASE 446 Garden tractor, it is hydraulic drive and has a 3 point lift. I would like to mount a sickle bar mower and other PTO powered implements if i can find the right combonation of motor, or motor and maybe a new bigger pump. the engine is an 16hp ONAN opposed twin,
Thanks for any help
Mike M
/ Hydraulic PTO Conversion #2
Mike,
It requires approx 8 HP to drive a pump producing 6 GPM @ 2000 PSI. This is based on approx 85% efficient. If you can size the motor and implements correctly it will drive them. NOTE: Expect roughly 70% efficiency on hydraulic drives Vs direct mechanical drives.
/ Hydraulic PTO Conversion #3
Have you looked into the hydraulic pto kit for the case garden tractors??
/ Hydraulic PTO Conversion #4
That is the best option for powering a hydraulic motor on the 3 point attachment. It is not mechanical, just plug the hoses in. It flows 9 gpm if I remember right.
I have that PTO for both of my tractors. What I want to do is mount a 6 spline output Hydraulic motor so I can power other 3 pt implements.
oldnslo,
So if I'm right i can upgrade my pump to 12 GPM and get a motor that turns about 540 to 700 RPM @ 12 GPM 2000 PSI
/ Hydraulic PTO Conversion #6
oldnslo,
If you have the 9 gpm set up I would stick with it. Going to 12 gpm would not leave any headroom for other loads. Just my opinion though.
/ Hydraulic PTO Conversion #7
oldnslo,
Yes if you have the input power available. 12 GPM @ 2000 PSI requires 16 HP @ 85% efficient.
2016 John Deer 5075E (A60462)
2016 John Deer...
Sakai SW354 (A60462)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
SET OF (3) CHEMICAL HOSE REELS (A63569)
SET OF (3)...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Informational Lot - Shipping (A63118)
Informational Lot...
