B2601 HST Pedal Stiff
/ B2601 HST Pedal Stiff #1
Woodybird
Toulon, Illinois
Kubota B2601, ZD1511, RTV900
I just took delivery of my 4th Kubota B series, a B2601. The tractor runs great and performs well, however the HST pedal is very stiff forwards and back. I can not find any grease fittings to fill and only see a neutral arm with two spring positions to choose from. Wondering if this is just a new machine and needs broken in or if their is an adjustment to make? My last three tractors all moved very smoothly and this tractor was fresh out of a crate. Any advice would be greatly appreciated! I lost access to my first account here from 1999, RBrown, man where has the time gone!
/ B2601 HST Pedal Stiff #3
G'day Mate and welcome to TBN from Downunder.
Well, it can't hurt to spray a good blast of Fluid Film (or a lanolin based lubricant) in/around where the pedal pivots. Spray anything 'mechanical' that moves, for that matter, all over your tractor (unless its got its own dedicated grease nipple). I go around my tractor and do this once or twice a year.
Enjoy the site.
/ B2601 HST Pedal Stiff #4
There is a grease fitting on the HST treadle of every Kubota I've owned/run, so I'd suspect the 2601 has one too. It will be described in the owner's manual. Some of the machines call for it to be lubricated periodically.
/ B2601 HST Pedal Stiff #5
I agree... both my FWD and REV pedals have a grease nipple.
Mind you, this fact wasn't included in my Owners Manual... 'they' had also removed two nipples on the front axle without updating the Manual. You live & learn, eh?
Thanks for the replies, however their isn’t a grease fitting anywhere on the pedal system. I will have the dealer take a look at it when they put the backhoe on. I just don’t remember by B3030 drive pedal being this stiff.
/ B2601 HST Pedal Stiff #7
Did you ever get this fixed.....what was done?
Unfortunately, not yet. I have ordered a shop manual to determine if their is an adjustment I’m missing. The dealer told me my tractor was fresh out of a crate and needs hours on it and it should loosen up. I still think my B2710 and B3030 were easier to press than this tractor. Reverse is the most brutal! My heal ached after plowing snow in reverse this year.
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2015 Chevrolet Express Shuttle Bus (A66736)
2015 Chevrolet...
MACK SINGLE AXLE(INOPERABLE) (A67714)
MACK SINGLE...
2015 Peterbilt 320 Roll-Off Truck (A66736)
2015 Peterbilt 320...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2025 Mini Excavator Attachment Set (A66734)
2025 Mini...
