Snow Blowers
/ Snow Blowers #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
It's that time of the year, and maybe this will be the year I finally adapt a QA snowblower to the front of the M59. The project is still in the planning stage, and all I've got so far is a wish list. That includes finding a snowblower to fit the standard Kubota skidsteer QA - which will take care of adjusting the snowblower height. Probably a windshield, and then hooking things up so that the blower is powered by the tractor. What else should I put on the list of features?
Or maybe this sort of rig is already available off the shelf & I just haven't run across it.
rScotty
/ Snow Blowers #2
rScotty
A hydraulic power pack to run the thing. I know TBLs have more hydraulics than a tractor, but I'm still pretty sure they don't have nearly enough to get anywhere close to PTO amounts of power. You'll need an appropriate pump on the PTO, some big lines as well as relief valves, a tank & maybe a cooler.
Any standard SSQA blower should work on a Kubota SSQA.
/ Snow Blowers
TLBs do tend offer more hydraulics than tractors, but most are optional. Our M59 only has a single additional remote hydraulic output. It feeds hydraulic power to the front of the loader and is controlled from the dashboard. Rated @ 16 gpm at 2800 psi but "not for continuous use". That's not much help except for something like a SSQA lever or maybe a grapple.
To get around the lack of hydraulics, I plan to put a supplementary hydraulic pump onto the PTO to run a hydraulic power pack. I think that doing that will make sense for lots of future projects. It will make real hydraulic power available everywhere without involving the expensive complicated HST+ and internal tractor fluids.
The hydro power pack will need the PTO pump, about a 12 gallon reservoir, as well as filters, hoses, and controls. But easy enough to do and a fairly inexpensive way to add lots of hydraulic power "on demand" to any tractor. The hydraulic power pack concept was well worked out for the Ag tractor community back in the 1970s, so the parts are high quality and very available.
So it's now two projects: The first one is the hydraulic power pack and then it won't matter which snowblower we choose, as all will work.
Time to get out the pencil & notebook and get to designing....
rScotty
/ Snow Blowers
Sounds like you want to build your own power pack, but it looks like they are available for purchase. Perhaps their designs will help with brainstorming the build.
Example: Loftness | Power Pak Hydraulic Power Unit Overview
http://www.landpride.com/ari/attach/lp/public/lit/lit_hrs30.pdf
Thanks for the links. Not only are the pics interesting, but it lets me know what to look for on the surplus market. Sometimes used implements like that pop up at industial auctions and such places. While I don't mind building my own anything, I'd rather save the time by going with something already made up. After all, the idea is to move snow....not to plumb another tractor. And I genuinely hate making brackets and mounts.
rScotty
/ Snow Blowers #7
QuickAttach.com builds a power pack used primarily with their blowers. There is a guy from Idaho on this forum has one,, I'll try to remember who it is.
EDIT: grsthegreat is the TBNer I was thinking of. He seems to love his, and the QA/Erskine model has all the needed features, a good one to look at whether you build or buy.
/ Snow Blowers #8
rScotty
I'd agree with most everything except the cheap part. They are rather straight forward & sorted out with easily avalible parts. But they or their parts aren't cheap.
And by enough hydraulics I meant flow, not number of remotes. Adding remotes is relatively easy.
/ Snow Blowers
I hear what you are saying, although part of it confuses me. That may be because I have missed some messages. This month I'm on the East Coast (Boston) and surprised to find that cell and wifi are even more "spotty" than in the mtns of Colorado.
Hydraulic parts are what they are....I didn't mean cheap as in "not many dollars", and certainly not as in "lacking quality". It was a poor expression on my part. What I mean is that hydraulic parts are all about the same price for everyone now that the lines between industrial, retail, and wholesale have become blurred by the profusion of internet suppliers. Frankly I'll probably buy all my hydraulic parts from Surplus Center. And I'll use their nifty on-line calculators to size components for flow.
As for flow (rate) I'll size for whatever blower I get. Leaving that loose for now. Probably use 25/30 GPM as a starting point. The M59 should be able to handle that.
Thanks, rScotty
/ Snow Blowers #10
Thanks, rScotty
There are plenty of calculators out there... Pressure * Flow and something = HP requirements. I'd spec out your power pack at around 75-85% of your PTO HP. You are probably pretty safe assuming a standard 2,500psi for figurin. Would be a good idea to check out some blowers & see what their requirements are before you start buying & building.
The Internet is definitely a great equilizer. And ya, the parts are comodity items & not specialty in any real way. None are inexpensive, but some are cheap.
/ Snow Blowers #11
You probably get more than enough snow to justify the FEL and power pack option I'm sure! However, you have the ideal tractor for a rear mount push behind blower.
The reason I say "ideal tractor" is because it's probably the only one I could imagine doing long drives with a rear push style blower.
Here me out....
If you were to bypass the safety switch on the seat so you could operate the tractor in reverse, and figure out a way to use the creep to position lever as speed control (I.e. Faster than a creep) then put a small electric over hydraulic motor on your steering rod, controlled by a joystick on your right side (facing backwards) then you'd have a very capable but compact bidirectional tractor.
The advantage of PTO power over hydraulic power is that you get much more power to the implement. Also, your pivot point is right over the rear tires so your tractor is considerably more maneuverable with a rear blower vs one sticking way out in front on the FEL.
Just an idea, but this is something I'd like to pursue if the day ever comes that I'm fortunate enough to own an M59/62.
A Pronovost TRC800 with rotating chute on the back of a tractor that you could face the direction your driving in would truly be impressive!
So basically this.....but spin the seat around and drive backwards.
/ Snow Blowers #12
Here me out....
I used to do something similar, albeit on a smaller scale, with my old B7100 HST and Woods SB54 snowblower. The tractor had a swivel seat for use with a backhoe. I attached a pole to the HST pedal to control speed. Most of my work is long straight runs so an occasional reach around to steer was all that was necessary.
Sadly, my newer larger tractors aren't so adaptable and I'm back to the stiff neck from looking over my shoulder. I may try one of your ideas on my MX5800 though. I now do most of my snow removal with a FEL mounted blade and resort to the blower only in deep snow or when the banks get too high.
/ Snow Blowers
Matt...Mr. Piston....Thanks for being so innovative. That is the most creative solution I've seen on TBN in a long, long while. I agree that it might even work better than you think. The creeper control on the M59 is somehow associated with both the range and plus shifters, so the M59 can potentially creep along at a pretty good rate depending on which gearing range is selected.
The downside is that without a cab it leaves me sitting out in the open almost on top of the snowblower. Hmmm....I'll have to think about how much that appeals.
Another even weirder alternative method would be to bolt a couple of motor-driven blowers into my spare FEL bucket and give that a go... What do you think of that?
/ Snow Blowers #14
Thanks Roger,
This idea I have, is one of the main reasons I really love the appeal of the M59/62. I believe it would be very helpful for many implements I use, especially the stumpgrinder and rotary cutter. I do a lot of work in reverse with the rotary cutter because the trees are too large to comfortably drive over.
The stumpgrinder is the biggest pain in my neck, and I believe a rear blower would be very similar.
I really don't think it would be terribly difficult to figure out with the help of Mtnviewranch and his hydraulic expertise.
Regarding the blowers in the bucket idea, I believe you'd be bogging down the blowers at a very slow speed and wouldn't be happy with it, but if you already have them then there is nothing to lose! :)
/ Snow Blowers #15
I've run both front and rear mounted snow blowers on my TLB's. I made an adapter to mount a 5 foot 3PH snowblower and ran a hydraulic motor to drive the PTO with a 16GPM hydraulic remote setup. I currently run a 6 foot blower on the back of my M59.
The front mount is great and saves your neck big time but the hydraulic flow just isn't enough for heavy snow. The other negative with my setup was that the blower sticks way out in front so if you need to negotiate a lot of curves or have lots of obstacles its slows you down and you can't get into as many tight spaces.
Running the rear mounted blower on M59 cut my clean up time in half. The hydrostatic drive is awesome as I can leave it in high gear and can vary my speeds easily and beats my old gear drive TLB hands down. The rear PTO never seems to get bogged down by snow and I never went back to the front mounted blower setup.
I just added a cab to my M59 so I'm actually looking forward to winter again this year.
/ Snow Blowers #16
Holy cow USD$6,000 for a power pack! Check out
2.7 GPM 54 RPM PTO Pump | Princess Auto
These are regularly CDN$599 and go on sale very year usually $100-150 off. You can build your own power pack with all new parts for less that half Loftness.com price.
/ Snow Blowers
I may have been trying to fit a snow blower to the wrong tractor. The M59's SSQA, cat II 3pt, and PTO seduced me at first, but now that we've discussed it I can see advantages to putting a snow blower on the JD 310SG. The JD doesn't have SSQA, a 3 pt, or even a PTO....but it does have a heated cab and an accessory flow circuit that pushes out 36 gpm at decent pressure - with cooling and filtration built right in. One of the reasons I didn't consider going that route is that attachments for the 310 tend to be somewhere between way too expensive and downright unaffordable. It's commercial; not homeowner.
In fact, I've never even looked to see if there is an SSQA adapter for the JD 310, but since there is someone who makes nearly everything else for the JD commercial backhoes, SSQA might be available. Anyone know?
rScotty
/ Snow Blowers #18
Roger,
That is a great photo!
I was interested in doing something very similar many years ago. The general consensus seemed to be that the weight and power of the full sized backhoe/loader would pretty easily overcome the design build strength of SS attachments.
http://www.tractorbynet.com/forums/attachments/245854-skidsteer-attachments-full-size-backhoe.html
The major disadvantage of this setup would be lack of maneuverability. Similar to a hydraulic power pack system and FEL mounted blower on your tractor, it's going to make for one LOOOONG package with a large turning radius. Just think of how far forward that blower would be, plus the backhoe sticking off the back of the 310.
If this wouldn't be a concern for you, then it may work out very well if you could find a heavy duty blower. However, to get a blower as heavy and wide as you'd need on the 310, I don't know if you'd be saving any money.
I'd think,you'd be well over $10k for something that stout, and still,risk damaging it very easily with the power of the 310. Personally, I believe your better off investing in a cab for your M59 and going with a rear mount blower.
I almost always think an inverted pull behind blower is better but in your situation I'm sure you get too much snow at one time for one of those.
Did you see the recent post on the Lauren cab install by a fellow from Canada? He did a great write up with some nice photos.
