X540 Nightmare, Help!!
/ X540 Nightmare, Help!! #1
daisyman
Member
Oskaloosa, Iowa
(2)Ferguson TO20, (2)Ferguson TO30, Massey Ferguson 35, Ferguson F40, 730 Case, AC WD45, 8N Ford, 631 Ford.
Hello everyone,
I'm working on an X540 for a guy. The deck will NOT turn on! I tried every conceivable way to get this to go. Does anyone have a wiring diagram for a unit with serial # 540D013283? This is in the first series of serial numbers, under 020xxx, made in 2007.
I've checked all the switches with a meter, safety switches, including the one under the foot pedal, activated the relays(2), the electric clutch( it works and runs the deck if hot wired), continuity of the wiring through the connectors, ignition switch, seat switch (it's jumped and has been for a long time), and put a tube in the back tire (LOL). They all check out good. The tractor starts and runs just fine.
I hate to go and buy switches and find out that's not the problem. Anyone can do that, is just costs a lot, and it's not mine.
What am I missing here? Is there one more place I haven't looked?? I'm hoping the wiring diagram might help. I've looked all over the internet for one, but can't find one. There's 3 serial number breaks for these machines.
Thanks, Irv
Good idea, but I'm not sure I can figure out the circuitry without a wiring diagram. I didn't know if there was some kind of electronic module I could ruin by applying voltage to the wrong spot, and I sure didn't want to do that!! What's the "interlock module" you're referring to?? And where is it?
This morning I tested the PTO switch and the switch under the foot pedal both on the NO and NC side under load (the electric clutch) and they all work.
Thanks for your reply.... Irv
/ X540 Nightmare, Help!! #3
Put the key in on position with the engine not running, put the PTO in on position, sit someone (or something) in the seat and measure voltage at the battery, then at the plug to the clutch (both with the clutch plugged in). The two measurements should be less than 2 volts different.
Aaron Z
OK, I tried that and I've got 12.38 at the battery and 12.17 at the connector to the clutch. So, I thought, I'll put a test light at the clutch connection and it came on. I also put it in the other terminal and it came on again, both sides!! So, I shut all the switches off and my test light STILL came on! Both sides! What's up with that??
The x300 schematic is posted here on TBN, and I suspect that the x540 will be similar. The module is one of those magic black boxes that contain the logic to control various "interlocked" functions such as the PTO and starting as examples. I suspect that it is under the dash somewhere, but I really don't know.
http://www.tractorbynet.com/forums/...ting-pto-problem-post2364943.html#post2364943
Thanks for the diagram. This one has a small black box that looks like the instrument panel module on the back side of the dash. I didn't know if that was it or not. I'm beginning to think that's the culprit. The thing is, that the tractor starts up and runs as it should, and has the "delay off " to the engine.
Update; I looked at JD parts online and an X300 does have a module, #AM134432, but the X540 only has a "display module". Same thing?? On the tractor it only looks like it just has the instruments in it but that "delay off" has got to be in there somewhere>
2ND Update; I think I'm getting too old for this. LOL That electronic module was up under the dash in plain sight!!! The thing of it is, this tractor is not supposed to have one and there is not one listed in the parts list. That started in the 2nd series of serial numbers, from 020000 and up. The number of the module is AM141075.
Irv
/ X540 Nightmare, Help!! #6
This is with the clutch connected? What is the voltage from wire to the other?
Aaron Z
Well, after looking at the wiring diagram I see that the PTO does indeed go through the module. So I went to my dealer and got a module, put it on thinking AHA, I got it now......
NOTHING, just like it was!! Oh boy.
I've checked some of the grounds as suggested. I'm going to do more investigating on those. Wish me luck, I've about run out of anything else.
Irv
/ X540 Nightmare, Help!! #9
post removed- after seeing ops post that applying + 12vdc does engage clutch??.
Concerning test light coming on, on both sides of clutch connection -Did you possibly connect the test light clip to the battery + voltage?
This would give the lights test probe access to ground through the clutches coil winding on either connection, assuming no voltage supplied by relay-
(Using the linked schematic that was posted earlier as a reference).
it seems there may be a different schematic that is an exact match for this machine.?.?
/ X540 Nightmare, Help!! #10
If you turn the key and the PTO on with someone in the seat, is there voltage on both wires if you disconnect the connector from the clutch? What you're saying sounds almost like the ground side is disconnected somewhere between the clutch and ground.
Aaron Z
/ X540 Nightmare, Help!! #11
That is what I posted and then removed because of the earlier statement that Hot wiring the clutch connector did engage the clutch-
This is key because it is not clear to me whether the connector was still connected or was removed and +12vdc AND Ground was applied.
If the connector was removed when the clutch was (hot wired) and both ground and power were both connected to battery + and -
And the linked diagram is in fact correct...
I would suspect a failed ground circuit from the clutch connector to the referenced schematic nodal ground point.
edit: Need more information from OP on exactly how the hot wiring clutch test was done.
Sorry guys for the confusion. At the beginning I put a jump wire from the battery to the clutch lead and the other lead to ground just to make sure the clutch was working, which it did, with the tractor running. Deck ran as normal.
Then I tested with a digital meter what I thought was the hot wire to the clutch through the fuses and main connector toward the dash. I had conductivity all the way. Without a wiring diagram, I wasn't sure just where it went. The wire loom is one big bundle.
This tractor has a diode in, what I see now from the wiring diagram for the X300, the ground wire side. That diode was open and I replaced it. I'm not sure what it does but I'm guessing it has something to do with the RIO.
I went on from there with me checking every switch with a meter and then rechecking them under load. All passed.
The new electronic module didn't do it either. NADA
I agree with you on the ground part, but all of them look fine. The battery ground bolts right to the engine base, and the controls ground wire bolts right on top of it.
I've pulled all the connectors apart, cleaned them with electrical spray, blew them out, checked them for continuity, and put them back together. They all look good.
I got to thinking when doing all this is, maybe I missed something......where is the switch that activates when you back up? I've looked everywhere under that thing and don't see it. There's got to be one don't there? Right?
Thanks for all your help,
Irv
I pulled the connector apart at the clutch and put a probe type test light on each lead with the ignition switch and the PTO switch both on and the motor not running. It lit up on both of them with the probe hooked to ground.
Then I took my digital meter and did the same....no voltage at all on either terminal. I don't understand that.
And yes, a diagram of the correct machine would be nice!
Irv
/ X540 Nightmare, Help!! #14
These two drawings are from jdparts key 12 in one and key 15 in the other are the reverse switch
/ X540 Nightmare, Help!! #15
If it is like the x7** tractors, the deck won't turn on if it thinks you are backing up. Once the deck is running, if you back up, the deck shuts off unless you pull up on the deck engagement handle. You can bypass this feature with a jumper behind the dash with one wire (to test of course).
"Once the deck is running".....That's the problem, I can't get the deck to run in the first place. I'm familiar with the RIO and did jumper the switch. Still no go! Too tired to think straight!!
I'll have to save it for another day.....or NOT. Ha!!
/ X540 Nightmare, Help!! #17
Another thing you have to check is the park brake switch. When park brake is applied, the pto will not engage. If switch is failed in the engaged position, it will not allow the pto to run.
Yes, as I said in my 2nd post, I tried all those switches under load and they all passed. I DID find one more larger wire connector back in behind the frame that I hadn't seen before. A real bearcat to get to. It looks fine from what little I can see of it, but I will look at it tomorrow.
Thanks
Irv
/ X540 Nightmare, Help!! #19
Irv
The B lead in the connector should be chassis ground... period. a point previous to X5 may be an open connection
assuming the diagram posted and linked is correct....
the A lead in the connector should be battery + voltage and since the diode is reversed biased should not reduce or affect the DC + available at that terminal.
that said I would back probe B terminal with a jumper to battery ( - negative terminal ) while everything is hooked up and PTO set to on with all conditions normally met for a functioning running PTO and see whether the PTO Clutch locks up and spins the PTO
I still have doubts since the same X5 is also the ground for the starter relay...
You may also want to check the outgoing Voltage and fuse itself
7.5 amp fuse 502b (blue wire) incoming to fuse and see if the test light comes on when trying to start PTO test light alligator clip to good ground.
ps. after all of the suggested help if that that fuse is just bad :confused2::laughing:
/ X540 Nightmare, Help!! #20
Irv
Not to be rude - but this post implies there is something wrong with your technique. You should have got the same result with either method and should not move forward until you have rectified this anomaly.
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
2022 EZ-GO ELITE...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
(INOP) 2022 MACK MD6 WATER TRUCK (A65054)
(INOP) 2022 MACK...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
