Crank Lift Arm Leveling Assembly
   / Crank Lift Arm Leveling Assembly #1
Dog Gone It
TN.
L2501 (4wd)
   / Crank Lift Arm Leveling Assembly #2
That one looks good. Will it fit your tractor ? Kinda expensive tho.....maybe a farm auction place will have something.
Good Luck.
   / Crank Lift Arm Leveling Assembly #3
I too had a hand crank leveling arm. It was on a 1964 David Brown 880.
Could easily adjust from the operators seat.
I have found several folks that make them. Here is a link to one.
Not sure this will fit yours though.
https://www.steinertractor.com/FDS0...MIibicgYfY1gIVAQ5pCh2guQnDEAQYAiABEgI6YPD_BwE
Try googling "lft arm leveling" or some variation thereoff.
If you have a rear remote, you can get them that operate hydraulically.
Thanks for the help.
Maybe they will make something that doesnt need to be modified.
Im fine with standard but I really like the crank handle.
   / Crank Lift Arm Leveling Assembly #5
The Grand L Kubotas come equipped with one of those, so they should be available from a Kub dealer. Probably not cheap. Kubota 3 point hardware also shows up on Ebay pretty often. My L4610 had one and it was very handy.
   / Crank Lift Arm Leveling Assembly #6
I just priced out the crank style leveling box from one of the older grand L kubotas to use on my new L3901 and the dealer priced it out at $571!!!!! Crazy money considering all the others I have found were around $100 give or take.
   / Crank Lift Arm Leveling Assembly #7
Some tractor salvage yards accumulate old Kubota hulks and sell used parts like this online much cheaper than new. Keep checking Ebay, etc., if it's not there the first time you look.
   / Crank Lift Arm Leveling Assembly #8
For $571 you could have a hydraulic side link. Well... almost.
   / Crank Lift Arm Leveling Assembly #9
If he has the rear remote, then it would be less than $571.
$400 for the side link.
$55 for the hose kit.
$15 for the flow restrictors.
??? UPS shipping costs. (probably around $40)
Just comes down to what a person wants. ;)
I wont be having a rear remote but thanks for the idea.
Thanks for all the other great ideas as well.
Maybe something will come along in time.
   / Crank Lift Arm Leveling Assembly #11
I used the crank style side link on my old L3430. In my experience it loaded up with debris frequently and was difficult to lube & clean. I much prefer the newer type which came standard on the L6060. I now use one on each side for a greater range of adjustment.
I'm not sure if it will fit the smaller L's though. I can provide dimensions if you need them.
Here's a link to the Messicks parts page. Kubota L6:cool:HST Parts Diagrams
I paid around $200 for it.
Here's a link to the Messicks parts page. Kubota L66HST Parts Diagrams
Sounds great.
Thanks for the reply.
I think I can run that idea by the dealership and see what they say.
   / Crank Lift Arm Leveling Assembly #13
My JD 1070 has one. No matter what the crank handle position is, the end of it will hit me in the head when hooking up an attachment.
   / Crank Lift Arm Leveling Assembly #14
Liked the one on prior tractor (64 David Brown 990). with crank handle similar to this one.
Would not work well on current Kubota since the ROP makes accessing the lift arms cumbersome fro the operator position and I have long arms.
Would like top and tilt, but can't convince myself to spend the $$s on adding rear remotes.
   / Crank Lift Arm Leveling Assembly #15
I was looking for a leveling box for my L3901 and found your post which led me to Weaver's Compact Tractor Parts as well. I bought one but had to make some modifications to it for it to fit. It has really worked well for me. I have attached a picture of it and here's a link to a video on how to modify it to fit a Kubota L Series tractor.
A Leveling Box for My Kubota - YouTube
Sounds great and thanks for all the help.
I really like that Youtube link with info. I believe Im going to check into this.
   / Crank Lift Arm Leveling Assembly #17
kioti sells one, about $90
Thats interesting. I wonder if it requires any modifications.
Thanks for the tip but I cant seem to find one.
   / Crank Lift Arm Leveling Assembly #19
The Kioti side links that are from the same frame size as your tractor have clevis tops, not ball swivels like the Kubota. To get a side link to actually interchange properly, you need the same or similar working lengths, same top type connection and same lower clevis and angles. To get all of these things from a different model is unlikely let alone from a different make.
My guess would be no matter what you find, some sort of modification will-should be made.
Good luck with your search.
Woods 18ft Batwing Rotary Cutter (A56438)
Woods 18ft Batwing...
2019 GALYEAN...
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
2007 Chevrolet Silverado 3500HD (A60462)
2007 Chevrolet...
