Box Scraper box blades...is bigger better?
/ box blades...is bigger better? #21
I know the OP has already made his purchase but thought I would add since I recently went through this process. I have an L-47 with 72" rear wheel width and opted for the 78" model from EA for 30-70 hp tractors. The first day I hooked it up I used it to grade a mound that I'd tried to build and then lower and level for about 12 hours with my FEL. Took about 6 passes and had it looking pretty good. Then I went over to the gravel drive way that a recent delivery had rutted up and ran a couple of passes to knock them out. I need to work a little more on that but the BB did great. Then I dropped the tines to about mid way and went out onto the bike trails that are in need of serious work. Within about 90 minutes I had the first two sections straightened up. Amazing how many roots this thing pulls up!
Point being, I'm a total noob, first time ever operating a box blade and you can really get some work done with these things! Slightly wider than your actual wheel width and heavy would be my recommendation! Anxious to get back to work with this new tool
/ box blades...is bigger better? #22
I just bought the same EA box blade. I took it out on its trial run to my VFW hall to level out an area for a parking lot. It worked great behind my 68 hp tractor. The fellas were very happy and I was happy to do it. Having never used a box blade before, I was surprised how much control I had cutting thin layers off the clay to get the drainage correct. It took some playing with the top link to get it where we wanted it, but it did everything we wanted and more. Very happy with the quality. Very reasonably priced too IMO.
/ box blades...is bigger better? #23
Now, just think about all that "playing" with the top link you did and how nice it would be to do that "playing" at the touch of your finger tips sitting in the seat using a hydraulic top link. ;)
/ box blades...is bigger better? #24
Brian......you are a devil in disguise.:laughing:
/ box blades...is bigger better? #25
Not me. :no: Only pointing out a rather inexpensive HUGE time saving feature that goes so well with a box blade as well as most other grading implements. :thumbsup:
/ box blades...is bigger better? #26
Brian, I send people your way all the time for those nice adjustment tools! :thumbsup:
Travis
/ box blades...is bigger better? #27
Travis
Thanks Travis, I try to do the same for the implements that I am familiar with. ;)
/ box blades...is bigger better? #28
Not sure how people are even able to adjust a manual top link on a heavy box blade. For years I used nothing but a manual top link and that was for a 5-foot box blade on my b7800. That experience made me want to rethink things for when I got my Kioti's box blade! Changing the rake on-the-fly is essential. Friends don't let friends operate box blades without hydraulic top links!:D
/ box blades...is bigger better? #29
"Not sure how people are even able to adjust a manual top link on a heavy box blade."
It's easy - just lower the blade til the weight's barely off of the top link, crank the toplink by maybe half a turn, reposition to take the weight off again, repeat maybe 17 MORE times, then get back on the tractor and TRY to remember what you DID it for... :D...Steve
(and yes, BOTH my smaller tractors have hydraulic top links )
/ box blades...is bigger better? #30
Come on, 17 times? It shouldn't be any more than 15, well maybe 16. :rolleyes:
I think that in reality, this actually causes "it's good enough syndrome". The cure is typically a good dose of Hydraulic top link. ;)
/ box blades...is bigger better? #31
Since this thread has to do with "is bigger better" I thought I'd share a surprising experience I had.
I already had a heavy duty 6.5' box blade which weighed 150 pounds per foot of width. I was really happy with it, but even at times I couldn't believe that it almost seemed like I needed more weight??
I ended up buying an even heavier box blade, which weighs 178 pounds per foot. I don't think there is a heavier box blade made that has hydraulic scarifiers, which I consider a must have.
The difference in weight doesn't seem that much on paper, it's only 28 pounds per foot heavier. However, I really do notice a difference, even that small amount made it more effective.
I'm typically working in pretty rocky rooted soil so it might not be a big deal in sandy soil.
Anyways, I wouldn't necessarily say that "bigger is better" (as long as it's covering your tracks) but I would certainly agree that HEAVIER is better!
/ box blades...is bigger better? #32
Go with the wider choice. When excavating a too narrow Box Blade will not clear a track wide enough for rear tires to enter aisle to make repeated pulls.
The key metric in Box Blades is weight per foot of width. It takes at least 100 pounds of weight per foot of Box Blade width to cut; 125 pounds per foot of width is better.
Construction grade Box Blades start at 200 pounds per foot of width.
Box Blades are the most common implement to do double duty as Three Point Hitch mounted counterbalance to a Front End Loader. So look up your FEL lift capacity and figure on buying a Box Blade 66% to 75% of FEL lift capacity. More than 66% is not necessary because Box Blade is cantilevered behind the tractor, increasing it EFFECTIVE weight as counterbalance.
I never thought about counterweight as a percentage of lift capacity before, but that sounds like a pretty good rule of thumb.
I'm curious about the construction grade box blades mentioned. Do you know of any makes/models that really do start at 200lbs per foot?
I think a 1400 pound 7' BB would be really nice!
(MUST have hydraulic scarifiers!). :)
/ box blades...is bigger better? #33
I did have remote top link....I made the guy watching adjust the top link for me LOL
One of your top links is on the wish list. I’ve just spent a lot of cash recently (thanks Travis ;) ). I didn’t really intend on getting my EA box blade this soon, but since I had a large order coming anyway, I added it and the shipping on it was basically free.
/ box blades...is bigger better? #34
Brian, that's funny!
One other thing to note, and that's that the top link on my B7800 seems to always be de-adjusting, I'm always checking and re-tightening it: so, rack up more on/off the tractor cycles!
Adams 5 T Fertilizer Spreader (A63688)
Adams 5 T...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A59914)
2013 CORPUS 40FT...
2012 International Prostar (A63118)
2012 International...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
