Generator shed
/ Generator shed #11
Eddie, I'm sure I am misunderstanding you but to be clear, you mean make a slit in the stucco and slip the flashing 'up' in behind it, right?
you want the flashing inside the slit cut by the saw, then filled with the flashing sealant, otherwise water can run behind the flashing on the chimney, i also put a bit of a upward angle to the cut.
/ Generator shed
I'm making my own door. I'm picking up garage door hardware and making my own panels, so it'll lift. That way I don't have to clear snow in front of the door to open out, and trying to open the door in would be pretty cramped.
I was trying to figure out how to install the flashing, thanks for the advice.
/ Generator shed #14
Nice progress, and I like the idea of making a mini overhead garage door for it. I'm curious though... why did you glue the blocks to the pad with caulk, rather than using mortar?
/ Generator shed
Landscape block adhesive goes in a caulk gun and is infinitely easier than mortar. I built a wall around my back porch a few months ago using the same stuff. I've also accidentally run my tractor into that wall, and it stopped my tractor dead in it's tracks. Wasn't fast, but wasn't slow, and had some momentum.
I debated doing the entire structure in cinder block. Honestly would have been about the same price. But my back still hurt from the last time I worked with blocks, and cutting them was a pain.
/ Generator shed #16
Yes. It's not possible or practicle to try and slide flashing behind stucco. You want it going into the stucco.
/ Generator shed #17
Inside transfer switch will go to 6-3 wire out the wall and into the generator shed, which will have an outlet. If i want to change generators, plugs, etc, it'll be easier.
This is the gen: Amazon.com : Durostar DS1E, 8 Running Watts/1 Starting Watts, Gas Powered Portable Generator : Duromax Generators : Patio, Lawn & Garden
Can you get a whole house generator from Generac for about the same cost as this one and what you are spending on the building? Where is the economy?
/ Generator shed
Not sure where you're getting your generac's from, the lowest price I've seen is $3400 for a 16kw. Also I don't have CNG or LP, and don't want to have a tank installed. And my generator cost $427 thanks to numerous mishaps by amazon. It started at 750 at the time, then delivery botched so credit $125. then there was a small dent in the panel, which was cosmetic only. I called and they refunded me an additional $198.
/ Generator shed #19
I remember your posts about that great deal. :thumbsup:
GyroTrac GT-25 (A60462)
GyroTrac GT-25...
Giyi GY-QSJ Mini QA Broom Sweeper (A60463)
Giyi GY-QSJ Mini...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2005 All Pro L7077 (A60462)
2005 All Pro L7077...
2013 Freightliner M2 TA45M Bucket Truck (A60352)
2013 Freightliner...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
