Question for fine tuning my homemade 6 wheel skid steer
/ Question for fine tuning my homemade 6 wheel skid steer #1
oceanside ca
homemade
Hello again everyone, its was a few months back when i posted for help about my creation.
http://www.tractorbynet.com/forums/hydraulics/382900-homemade-6-wheel-drive-cart-new-post.html
I have since bought a smaller pump/larger motors and it seems to be working pretty well. I have moved hundreds of pounds of dirt up a very steep incline without feeling sore the next day. I'm now dealing with runaway motor issues and before purchasing crossover valves and hoses I would like some input.
The situation- so when going down my very steep hillside the cart will sometimes runaway completely, with the control valves in the forward moving position or neutral (closed). I can open the valves to go backward and this does stop the cart immediately but i know this is terrible for the components of the system. If i descend very slowly the cart becomes jerky as if i can feel each revolution of the motor as they're being turned by the load (the wheels and weight of the cart) but all of a sudden it picks up speed even if i let go of the control valves. I assume the motors are experiencing cavitation because both inlet and outlet ports are blocked at this point.
Before I spend the time and money for crossover/cushion valves I just want to make sure they will provide the slow and controlled descent im hoping for. I have ordered a flow control valve (with relief) and will dial back the flow while descending.
Surplus Center has two listed 500-1500psi or 1500-3000psi. I have my system pressure limited to 1800 psi (17cu" motors max rating) and im wondering which ones would be suited best for my application.
/ Question for fine tuning my homemade 6 wheel skid steer #2
You are describing the function of counterbalance valves. These are designed to reduce or eliminate runaway conditions. I would suggest a pilot ratio of 8:1 or 10:1 for use on motors. When set properly these will provide a controlled braking action while going down hills.
Excellent thank you, I figured they would do the trick. I suppose the 1500-3000 psi is a better choice? The motors intermittent rating is actually 1600 psi but im pushing the pressure just a tad more (1800psi) for those extra heavy uphill loads.
/ Question for fine tuning my homemade 6 wheel skid steer #4
Typical counterbalance setting is 15 - 20% higher than system pressure. You may have to experiment but that range should be good starting point.
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2016 Chevrolet Tahoe SUV (A59231)
2016 Chevrolet...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2018 Dodge Journey SUV (A59231)
2018 Dodge Journey...
