robbyr
Elite Member
The Mahindra 4500 is parked right in the way in my back yard but won't start. Was using it last Saturday and everything was fine. Sunday it wouldn't start. Starting some time I ago it started having issues with a safety switch I think. I could slide pto lever back and forth slowly while holding key on til the starter engaged. Then I found sometimes I could wiggle the range selector lever in neutral position and that seemed to work. Sometimes neither would work and I'd jump across the solenoid and it would start right up. Next time I might turn the key and it start right up. Sunday nothing worked. Battery is only 9 months old but I cleaned cables and put charger on anyway. Turn key or try the screwdriver thing and it clicks once and that's it. Nothing else. Battery tester shows in "green". Thought maybe just didn't have enough voltage to engage starter but kinda scratching my head now.
