1972 ford 5000 steering question
/ 1972 ford 5000 steering question #1
tylertown
MS
Massey Ferguson 40 backhoe, Ford 5000 general purpose
My tractor is a 1972 ford 5000 and has factory power assist with a engine mounted pump and last year about this time I put all new o-rings in the sector and valve body.
My question is when I let go of the wheel it feels like the power steering is trying to return to center but center is slightly pulling me left I have to hold tension on the wheel to the right to drive straight.
The reason I re sealed it all is because it was leaking out of the steering wheel.
The wheel is easy to turn to full lock in both positions but just wondering if I got something off when I read sealed it because I only used it a few times before I tore In to it shortly after I bought it but I don't remember it pulling.
By the way I need tie rods because the previous owner at some time welded washers over them to keep from popping out.
Any input is greatly appreciated thanks in advance.
Also I have car tires on the front and on the driver side I have a gap between the tire and the arm that the tie rod connects to but on the passenger side the tire rubs the arm once during a rotation could this indicate a bad wheel bearing or hub?
Thanks.
/ 1972 ford 5000 steering question #3
Were there any shims in the steering gear you may have put in the wrong place? I don't know anything about your tractor, but I rebuilt a Ford car power steering gear and I put some shims in the wrong place and it pulled to one side until I fixed it.
That is very possible I may have an extra on top of bottom of the valve body. Thanks I will look into that I thought I had them right but from what you say I may need to loosen it back up and check. Thanks!
Hedge Posts (A65640)
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
2007 Hooper 20ft Equipment Trailer (A65563)
2007 Hooper 20ft...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
