4200 Hydraulics
/ 4200 Hydraulics #1
skipoff
woodinville
John Deere 4200
Ok I have read most of the posts here and can't pinpoint my issue. Tractor movement works, pto works, bucket does not and power steering does not. I am assuming Kenny will respond to this being he is known here as the hydraulic god. :D From what I have found is the steering pump is separate which confuses me why two pumps are not working. And there must be a third pump since the tractor will move. I do here a pump "noise" tho. I have heard the similar noise out of a failing power steering pump on a car. I am a lamen when it comes to tractor terms so please don't use slang or abbreviations. I don't even know where these pumps are located and/or how many i even have on this tractor. Thanks in advance for anyones help.
/ 4200 Hydraulics #2
Just a silly question but have you checked your fluid levels?
/ 4200 Hydraulics #4
Ha I'm flattered :)
Yes there are two pumps, one for the implements and one for the power steering, the steering pump also supplies charge pressure to the hyrdostat so it's odd that the tractor moves OK, but the steering does not work.
I would check two things first:
1) Do a simple pressure test, make (or buy from us) a test gauge, that will help tell whats happening. We have a video on the website and YouTube showing how to do this simle test.
2) Check, or better yet just replace the rubber "hose" AKA "manifold" (#2 below) between the main pickup line and the pumps, these are known to crack and cause the system to suck air. Anyone with a 4x00 series machine should be checking/replacing these after all these years, its cheap insurance that can save the pump for only $20 or so.
TRANSMISSION SUCTION LINE AND IMPLEMENT PUMP LINE
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 TY22467 Clamp 2 (SUB FOR AR21839)
2 M136804 Hose 1
3 TY22467 Clamp 2 (SUB FOR AR21839)
4 AM125064 Oil Tube 1
5 LVU13981 Spacer 1 (SUB FOR M136079)
6 M136830 Bracket 1
7 14M7298 Flange Nut 1 M8
8 M135933 Hose 1
9 TY22467 Clamp 1 (SUB FOR AR21839)
10 38H5004 Adapter Fitting 2
11 51M7045 O-Ring 2 19.300 X 2.200 mm
12 T77932 O-Ring 2
13 AM125062 Oil Line 1
14 19M7868 Socket Head Screw 1
15 T38377 Clamp 1 (FOR WIRING HARNESS)
16 14M7298 Flange Nut 1 M8
17 19M7865 Socket Head Screw 1
18 U12288 Clamp 1
19 19M7789 Socket Head Screw 1
/ 4200 Hydraulics
Ha I'm flattered :)
2 M136804 Hose 1
6 M136830 Bracket 1
8 M135933 Hose 1
12 T77932 O-Ring 2
18 U12288 Clamp 1
Thanks for responding. I will replace the manifold and do some pressure testing. You say this has two pumps. The one this manifold is hooked up to... is that the pump for the loader or is that the pump for the power steering and hydrostatic drive? Any idea where I can get a service manual for this tractor? I see a few online i can buy but not sure if they are decent and will show me what i need to know. Not interested in pictures of the steering wheel and explanations what is used for. lol. I want hydraulic schematics and technical stuff.
/ 4200 Hydraulics #6
I can't get to jdparts now...but the pumps are mounted in tandem (back-to-back) so it's not easy to see both.
Tech manuals are available from your dealer, or GreenFarmParts online. I can help out later with some links...
/ 4200 Hydraulics
Thanks. I saw somewhere someone said its costly to replace the pumps if they are fried. I found pumps online and they don't seem to expensive and if they are exposed and not internal isnt it just an unbolt and bolt on new? Also, took off manifold and inspected and cleaned. Looks fine but I will replace once I solve problem. But, after starting again, forward and reverse motion struggles but I also noticed that the manifold collapses. Pretty sure that is not normal operation for it. lol Thinking about pulling of screen under *** end of tractor where the tube from the manifold connects into (assuming that is location of screen) and cleaning. Really appreciate your help. :)
/ 4200 Hydraulics #8
Skip,
If the manifold is collapsing, you have a blockage on the return side-I'd get that pickup screen out ASAP, you'll have to dump all the fluid to do that. I assume you have the owners manual?
When was this last serviced? Including pickup screen cleaning and changing the fluid and main filter?
Fluid clean and clear? Or foamy/milky looking? Not it's possible for the fluid to grow an algae that can really gum up the works.
Here is the screen, #4:
TRANSAXLE HOUSING
1 YZ80608 Transmission Case 1
2 34M7061 Spring Pin 2 8 X 20 mm
3 F85006 Fitting Plug 2 (SUB FOR F85106)
4 YZ81443 Filter 1 (SUB FOR YZ80887 OR YZ81252 OR YZ81413)
5 YZ81448 Gasket 1 (SUB FOR YZ80152)
6 YZ80947 Cover 1
7 F190038 Pipe Plug 1
8 19M7867 Bolt 2
9 YZ81085 Drain Plug 1 MAGNETIC
/ 4200 Hydraulics #9
Any chance someone opened or closed the valve behind your left foot when sitting on the tractor?
/ 4200 Hydraulics #10
What valve is that on a JD 4200? Are you thinking of the rate of drop valve for the 3PH? If so how would that affect the entire system?
/ 4200 Hydraulics #11
Rate of drop valve.
It's the valve that has to be closed for the backhoe hydraulics to work.
The hydraulic mower lift may also become involved???
/ 4200 Hydraulics #12
manuals are available direct from Deere...John Deere Technical Information Store
/ 4200 Hydraulics #13
I'd get the suction/filter problems fixed first, then check the valve lock by your heel. If any QD couplings are not completely seated they will also cause trouble. (like the Power Beyond for a back hoe).
/ 4200 Hydraulics #14
I just went through the same symptoms that you're having with my 4200,I had a cracked suction hose ( the one that Kenny is talking about) picked up a new one $24. This is the 3rd one that I've replaced in the past 10 years.
John Deere 6140R Tractor (A64047)
John Deere 6140R...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
Front and Rear Studded Tires (A63116)
Front and Rear...
2014 John Deere 644K High Lift Articulated Wheel Loader (A61572)
2014 John Deere...
