Still Have to Change Coolant Every 2 Years?
   / Still Have to Change Coolant Every 2 Years? #21
I change the coolant when the water pump goes bad.
I change mind when the radiator hose goes bad, with second hand anti freeze.
   / Still Have to Change Coolant Every 2 Years? #22
I Never change my coolant in any vehicle unless the radiator has to come out for another reason, and that is very seldom. Every year I add additive package. No cooling system issues or failures in +million miles, thousands of hours.
I have vehicles going on 20 years.
   / Still Have to Change Coolant Every 2 Years? #25
In my truck SCA is required. In the tractor, I don't know if it's required or not but use it regardless. I'd have to check the jug to be sure, but 5 years sounds familar.
   / Still Have to Change Coolant Every 2 Years? #26
If you use green coolant you can add something with SCA's. I've used Winns before. In my 4610 SU I use the Ford FW15. Here is a Motorcraft version.
Genuine Ford Fluid VC-8 Diesel Cooling System Additive - 16 oz. | eBay
Amazon.com: Prestone AS18 Radiator Complete Care - 22 oz.: Automotive
Genuine Ford Fluid VC-8 Diesel Cooling System Additive - 16 oz. | eBay (Thanks for tip!)
As I had to remove the radiator in my 2003 Terminator, First time change in 14 Years, This time I used Royal Purple Purple Ice. Old Antifreeze still seemed fine. From what I could see, there was absolutely no corrosion or sludge in the cooling system or jackets. Steel cooling lines were shiny metal internally also.
   / Still Have to Change Coolant Every 2 Years? #27
Nice looking engine bay !
   / Still Have to Change Coolant Every 2 Years? #28
FTR, SCA does not protect the radiator (hoses, lines, etc...), reduce sludge, or inhibit corrosion. SCA is depleted through use over time. There are test strips available for SCA, but IIRC they aren't accuarate in some applications.
   / Still Have to Change Coolant Every 2 Years? #29
SCA is primarily for mitigating cavitation induced corrosion, in older coolant formulations.
Personally, I would rely on just SCA to deal with chemical corrosion, long-term.
Rgds, D.
Freightliner Tender Truck - Adams Tender (A56436)
Freightliner...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
John Deere 4510 (A53317)
John Deere 4510...
2018 FREIGHTLINER M2 SINGLE AXLE DUMP TRUCK (A59575)
2018 FREIGHTLINER...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
