Still Have to Change Coolant Every 2 Years?
   / Still Have to Change Coolant Every 2 Years? #12
In the area I live in used coolant can be disposed of at designated recycle depots.
   / Still Have to Change Coolant Every 2 Years? #13
I change the coolant when the water pump goes bad.
   / Still Have to Change Coolant Every 2 Years? #16
Excellent tip ! And easy !
In the distant past, I've seen conductivity vs. lifespan graphs.... somewhere..... so, I can't vouch for those exact #'s in the quick link I found, but they'll probably do as a rule of thumb.....
Rgds, D.
   / Still Have to Change Coolant Every 2 Years? #17
The junk yards around our area sells old antifreeze taken out cars before being parted out. Guess they figure if it looks green or orange it's good. Sure they don't care as long as they make a few extra $.
   / Still Have to Change Coolant Every 2 Years? #18
Maybe that's a cover up plan for dumping it on the ground. I can't imagine anyone stupid enough to buy second hand antifreeze.
   / Still Have to Change Coolant Every 2 Years? #19
:laughing: could be!
   / Still Have to Change Coolant Every 2 Years? #20
My (4) Kubotas all came with standard green coolant, which should be changed every 2 years. I have always replaced the oem coolant with a hoat (hybrid organic acid) coolant that requires changing at 5 years.
Whatever coolant type is used, I would replace it at the required interval.
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A59575)
2016 FORD F-550...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
8065 (A55852)
8065 (A55852)
2015 GENIE GS-4047 ELECTRIC SCISSOR LIFT (A52706)
2015 GENIE GS-4047...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
