glow plug wiring
/ glow plug wiring #21
the picture on the left has a wire hooked up to round item, don't know what that is, but I found this hanging loose under tractor. the yellow wire goes to the solenoid, and the other wire goes to switch. I found that round item and it looked like it hooked up to it. it had two terminals on it that fit. I learning.
Possibly engine stop solenoid.
Dave M7040
/ glow plug wiring #22
Looks like a oil pressure sending unit being that it's piped to the engine block.
/ glow plug wiring #24
It's hard to tell with the angle of the picture if it's connected to the block or the inj. pump, my 385 engine has a manual stop cable at the inj pump.
/ glow plug wiring
Dose anybody know where i can get the switch assembly on the middle pis. Need Help
/ glow plug wiring #26
Call Tommy at Affordable Tractor, he might need that picture they are on the web.
/ glow plug wiring
I found out where the two wires went to. They went to the clutch safety switch.
Thanks all.
2015 Mack Granite GU713  Tri-Axle Dump (A62613)
2015 Mack Granite...
2015 JCB 536-60 Loadall (A64126)
2015 JCB 536-60...
Exmark C2-96 (A64127)
2018 VOLVO VNL 670 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 670...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
2023 Wolverine DM-13-72W Mulcher, Skidsteer Mount (A62679)
2023 Wolverine...
