New tractor house started
/ New tractor house started #1
LS Tractor Owner
Super Member
Edgewood, NM
LS XG3025 TLB, Previously MT125 TLB, Craftsman GTS6500
Started building a new "tractor house" as an addition to our shed. Area for tractor will be 12x20, area of 6x20 for work bench / tools. Above the 6x20 will be a storage area also 6x20x78" high. Got all the posts and beams in place, perimeter footer, and framing for 8x8 garage door. Have to go back on duty tommorow for 3 days, (so I can take a break... Forgot how much work it is to frame.... Maybe I'm just getting too old) I won't get a chance to get back on it until Sunday. The tarp was a necessity to get out of the sun... Sure was strong at 7200 ft elevation and 97 degrees for the past 3 days! image.jpegimage.jpegimage.jpeg
/ New tractor house started #2
:thumbsup:...more room the better in years to come for those attachments. ;)
Pace yourself.
Here are a couple more pics of the garage build, made a little progress. Got $1700 worth of cedar siding today. Metal roofing coming tomorrow.
/ New tractor house started #4
It's gonna have a nice look to it. I'm a big fan of that style of barn!!
can't tell for sure, but looks like a couple, white one and yellow/orange one?
Yea there's a white 72 that was started restore, the yellow/ black one is a 69, full ground up restoration. Only have 50 miles on the 1776cc motor in the yellow one. Looking to sell both for a sweet deal including 2 motors for the white one and all brand new peripheral items. If anybody knows someone looking....
How much concrete did you have to mix and pour?
For the footers and stem wall was 85--- 80# bags. Done over 2 days. Lot of work. The slab will be 3.5 yards, but I'm gonna do redi-mix.
/ New tractor house started #10
Started building a new "tractor house" as an addition to our shed. Area for tractor will be 12x20, area of 6x20 for work bench / tools. Above the 6x20 will be a storage area also 6x20x78" high. Got all the posts and beams in place, perimeter footer, and framing for 8x8 garage door. Have to go back on duty tommorow for 3 days, (so I can take a break... Forgot how much work it is to frame.... Maybe I'm just getting too old) I won't get a chance to get back on it until Sunday. The tarp was a necessity to get out of the sun... Sure was strong at 7200 ft elevation and 97 degrees for the past 3 days! View attachment 515252View attachment 515253View attachment 515254
The temporary tarp certainly was a helpful idea for protection from the blazing sun.
If you need to do something like that again, it might be worthwhile to search for a silver tarp, rather than blue.
The silver color will reflect heat, while the blue absorbs it.
Well it's been over a month of bustin hump on the days off from work, but the new shed / shop is almost complete on the outside. I have a bit more painting to do and install the garage doors. Then I get to work on the wiring and interior finishes. Here are a few updated pictures. One is of the sun setting over the mountain, pretty nice because of all the smoke haze coming from the wildfires up in the NW.
/ New tractor house started #12
Nice looking little building.
/ New tractor house started #14
Very nice, your tractor will enjoy it's new home.:thumbsup:
Finally finished the exterior and sealed it all up. Did the final grade and entrance gravel. Incorporated some of the existing landscape w/ some new timbers. Next up... The arduous task of organizing all the tools and building the workbenches. The upper 4' of the interior walls will have pegboard almost all the way around. I'll post pics of the inside when done.:dance1:
/ New tractor house started #17
Tell me about the JK, where all done to it? Looks like a custom rear bumper with 3 NATO cans instead of a spare tire? What mirrors are those?
The bumper was made by "OR Fab"(off road fabrication). The swing away cage mounts to the body behind the tailgate hinges, separate from the bumper. The cans are Roto-Pax, which are available from 4wheelparts. The spare tire does mount to the cage in the center, up high, on a threaded post that sticks out using a "T" shaped spin on lock w/ a large rubber backed round plate that centers the wheel on the post. It's lockable also. The mirrors are stock mirrors mounted on extended arms I made from 1 1/2" x 3/4 steel rectangle stock. I used 3/8 round thin wall tubing for the support arms under the square stock. I mounted the arms onto stock Rugged Ridge mirror relocation brackets. I extended the mirrors out because I pull a 17' travel trailer out to the areas I want to wheel and it was hard to see around it. The mirrors and arms will come off the brackets in a couple of minutes when I get out to the trails if needed. It's dark and raining right now but I'll try to take some close up pics so you can see the simple set up of the mirrors. I go on duty tomorrow morning at 4 am, for 3 days, so I probably won't get to take them or post until Sunday. If I get a chance sooner I will.
/ New tractor house started #19
Nicely done on the landscaping. It looks like it's been there forever.
/ New tractor house started #20
Looking good.
Massey Ferguson 250 Tractor (A62613)
Massey Ferguson...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
3 Bag Air Jack (A66408)
3 Bag Air Jack...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
2011 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2011 FORD F-550...
