Ebay fuel pump
/ Ebay fuel pump #2
I have been running a $9 eBay fuel pump in my F150 for the last 17 months and 13K miles with no issues.
/ Ebay fuel pump #3
I have one just like that on my diesel standby generator. Only has about 25 hours on the pump, but it works fine.
If you find a source for a mating plug, please let us know. I had to cut the plug off and solder the wires.
/ Ebay fuel pump #4
I just ordered 3 replacement inline 12v fuel pump on eBay New Universal 12V Gas Diesel Fuel Pump Inline Low Pressure Electric Fuel Pump | eBay because the oem crapped out on my Yanmar. Has anyone used these eBay ones before? I cant see paying over $100 for an new oem pump.
I've had better luck with the fleabay pumps than I have with the 60 buck pumps from the parts store. Of course, when I need one it's a NIRTS moment(Need It Right This Second) so parts store it is, I really should just buy and extra and throw it on my shelf.
/ Ebay fuel pump #6
I have had 2 of these go out on me so far. Not exactly sure if from the same mfg in China. I paid about $15 apiece for mine. There is a rubber diaphragm inside that goes bad. I wish someone could figure out the Japanese part number and find it cheaper than thru Deere. IIRC it is possibly a nippondenso?
/ Ebay fuel pump #7
I would suspect the diaphragm is actual rubber and it is well known that the alcohol laced gas eats the rubber.
Switching to a pure gas might just be the solution.
/ Ebay fuel pump #8
/ Ebay fuel pump #9
Jus put one on my Mahindra last night, it fired right up , been chasing fuel issues for a week with member Spanners help , warning if you use economy shipping expect a 10 day delivery
I also orderd a heavy duty pump from Jegs for back-up , its under Autobest brand name for $23 , it's the same pump as the auto parts houses sell with Mr Gasket brand name for $64
Hope this helps
/ Ebay fuel pump #11
On some of the plugs you can reach in side the plug end with a small screwdriver and depress the tab on the electrical spade and pull it out from other end , then push the new wire thru the plug with spades attached till they click into place
Hopes this helps
UNVERFERTH H25 - 25' HEAD CART (A64277)
UNVERFERTH H25 -...
2015 IC Corporation PB105 School Bus (A61573)
2015 IC...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
66in. Skid Steer Bucket (A65640)
66in. Skid Steer...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
We do NOT accept credit cards as payment. (A64126)
We do NOT accept...
