DS4110 Remote Hydraulic Kits???
/ DS4110 Remote Hydraulic Kits??? #1
kantuckid
Eastern KY
Branson 4820R
I was unable to find the part number/price for this kit for a 2014 DS4110 Kioti tractor?
Google says they also fit the DS4510?
FWIW, I installed the kit on my DK40 some years back-is this a similarly done install?
Prices are much higher for this kits?- I'm thinking these are in the $380-$400 parts range?
I am looking at a tractor for sale that lacks the rear remotes and need to get the ballpark cost thrown into my decision. I'll do the wrenching.
Thanks, I saw those but based on the kit I put on my current tractor I couldn't make the connection.
/ DS4110 Remote Hydraulic Kits??? #4
Yea from what I see it looks similar to what they did with the old CK series and used some proprietary housing & connection. The stuff on the newer CK10 series looks totally different and much more "standard" - I suspect this is to reduce machining & manufacturing cost by using off the shelf components.
If you contact MIE they can confirm if that's the right thing or else tell you what you need.
I had them quote me the 2 remotes for our CK I just can't justify $800 for 2 rear remotes that I have no use for yet (other than I'm afraid they will quit making them / run out and I'll be stuck with an aftermarket solution)
Good Luck.
