newbury
Super Star Member
- Joined
- Jan 8, 2009
- Messages
- 14,866
- Location
- From Vt, in Va, retiring to MS
- Tractor
- Kubota's - B7610, M4700
I need some schooling on mini-splits so I'm not dumb when dealing with my son.
SWMBO has a 12x26 "Craftroom" that requires cooling to 74 degrees. It's in Mississippi, in full sun and last month the temps were hitting 100 degrees plus. The room is located above a garage that was transformed into a library. The room has 3 large windows. It has one small duct from our central a/c that looks like it was added as an afterthought and has all the cooling capacity to prevent water boiling.
I've initially put in an 8K BTU window unit (which I had from another house) which labors to keep the room temp down to 76 (not enough says SWMBO).
A downside to that is the noise and it blocks half a window. It looks like a 10K BTU window rattler would cost about $250 plus.
Amazon lists a 9K BTU mini-split kit for $600 so it seems prices are getting pretty close.
And my ace in the hole is that we've a son who is a licensed a/c tech and could finish the install with the proper tools.
So what I'm wondering is:
Would a 12K 110V 15 SEER system for $650 do?
How much savings (ballpark) would I see stepping up to a 12K 220v 22.5 SEER system ($1200)? The unit will probably run all summer.
What other brands should I look at?
The ceiling is a gambrel roof, about 2' high at the sides and 8' in the center. Can the inside unit be mounted at an angle or is it better vertical?
Is running a 220V (actually 240) line worth it? I've a relatively easy 50' to 70' shot from the breaker box, w/ plenty of spare breaker room to put in a new 240V line. I suspect I'd have to run a 20A line if I went with 110V (actually 120).
I've a concrete driveway just outside the former garage to base the outside unit on, and would run the wire through the wall adjoining the driveway.
The attached pic shows where I thought I could run the power line easily and 2 potential site for the compressor/coolant lines.
Advice? Pointers? I"m pretty sure we can get our son to help (he's 3 hours away in Memphis) but I like to do the research myself also. Besides, Hurricane Harvey rains are shutting off outside work and the noise level in my workshops is up around 72 decibels at times.
