Loader Lifts but not smoothly
/ Loader Lifts but not smoothly #1
jpt46
Conroe, Texas
JD 790 w300 loader
I recently had a lifting cylinder leaking. I had packing changed and reinstalled cylinder on tractor. The loader works but it has a jerky motion when lifting. I can also feel a jerky sensation in the steering wheel. The jerky motion in the steering was there before I changed out the lift cylinder. I am thinking of changing out transmission/hydraulic filter, clean the screen and change out the transmission/hyraulic oil. What do you think, any suggestions welcomed.
/ Loader Lifts but not smoothly #2
When was the last time you thoroughly greased the FEL?
Kubota calls for greasing FEL every TEN hours of use.
Are the extending hydraulic arms, usually chrome, smooth and corrosion free?
/ Loader Lifts but not smoothly #3
Hydraulic systems aren't meant to 'jerk' :eek:
When was the last time/hours the hydraulic system was 'serviced'? <<<
Screen would be first on my agenda.
FEL is greased but don't usually grease after 10 hours. Extending arms are smooth and corrosion free.
Not for sure. It has been many moons for sure. From what I have seen it looks like I have to drain the transmission to check and clean the screen.
/ Loader Lifts but not smoothly #6
Yup. Drain the oil into a clean container so you can inspect it for debris and metallic particles. View it in the sun. Drag a magnet through the oil.
Post a pic of the oil and the screen if poss.
/ Loader Lifts but not smoothly #8
How many times did you cycle the loader full up and full down after changing the cylinder?
/ Loader Lifts but not smoothly #9
Mr. Obvious: Did you top off the reservoir after losing that fluid?
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63118)
Greenworks...
2024 SILVERBACK 53XH3A 53FT TRI/A GOOSENECK CAR HAULER TRAILER (A59910)
2024 SILVERBACK...
2019 ALLMAND LIGHT PLANT (A63569)
2019 ALLMAND LIGHT...
